Intermittent engine rattle and noisy tappets!
#81
Posted 08 April 2016 - 02:28 PM
#82
Posted 08 April 2016 - 03:23 PM
#83
Posted 08 April 2016 - 03:34 PM
#84
Posted 08 April 2016 - 03:54 PM
Going in on Sunday night after a good thrashing ready for Monday morning techs heard the noise and hopefully will sort it out for me I must say they have been very patient with me and have done everything they can so with a bit of luck and diagnosis of the faulty parts they can put it right and I have a mint RS3 !!
Is this @Poole Audi ?
I have to say my experiences with them , limited though they were to the front brake issue, was top notch!!
BMW M2 in Mineral Grey
Audi A4 Avant 2.0 TDi Black Edition
Used to have a Condor Grey RS3 8P, and before that a further 47 assorted money pits
#85
Posted 08 April 2016 - 03:56 PM
#86
Posted 08 April 2016 - 04:27 PM
#87
Posted 08 April 2016 - 04:34 PM
Lets hope they get it sorted and you can enjoy the car!
So much temptation when you visit the dealers hey!
#88
Posted 08 April 2016 - 04:37 PM
#89
Posted 08 April 2016 - 04:47 PM
Yeah i had one pull up beside me yesterday and was drooling! An old dear was driving it too, must be her husbands!! lol
#90
Posted 08 April 2016 - 09:59 PM
#91
Posted 09 April 2016 - 07:27 AM
Very excited to see the new RS4 going back to the original forced induction!
yeah buying approved used from Audi is going to be the safest route to RS ownership. That or buy one from a fellow club member on here when you know the history
#92
Posted 09 April 2016 - 07:28 AM
#93
Posted 09 April 2016 - 07:52 AM
I've got a slight noise from the gearbox when idling in Park or Neutral but having spoke to many others it seems it's not uncommon and it's not enough to worry me. Will get the stronic serviced this year and see if there are any marked improvements
Edited by Mattjj82, 09 April 2016 - 07:55 AM.
#94
Posted 09 April 2016 - 03:47 PM
I think I heard the techs at Audi say there are two parts that could be causing the issue I may have this wrong but I think they said I could be two variable valve guides at the top near the chain ?? It could be that oil is running out of them and causing the nasty rattling so will see by Monday
David8
I`m surprised the variable cam sprockets weren`t changed when they did your chain.On mine when the chains etc were changed the variable sprockets were also swapped.It turned out that it was in fact these that were the culprit.If you have access to VCDS you can check the valve timing isn`t jumping about all over the place.
#95
Posted 09 April 2016 - 04:44 PM
#96
Posted 09 April 2016 - 08:20 PM
Ok I will pass info onto techs on Monday if these two parts were not replaced at the same time as the chains would these parts being faulty affect the new chains I have had fitted ? do you think once these are replaced all should be ok or does it all need to be re done ??
David8
If the sprockets do turn out to be faulty I doubt they would affect the chains at all.
#97
Posted 09 April 2016 - 08:31 PM
David8
In the end it wasn`t my chains or tensioners that were faulty but the sprockets but Audi UK wanted to be sure so they said just change everything relating to driving the cams.I`m staggered yours weren`t done.It means the whole lot has to come apart again.Hope you get it sorted.
#98
Posted 09 April 2016 - 08:56 PM
#99
Posted 09 April 2016 - 09:55 PM
#100
Posted 09 April 2016 - 09:57 PM
