Intermittent engine rattle and noisy tappets!
179 replies to this topic
#121
Mattjj82
Mattjj82
  • 907 posts
I'm presuming you're running the full standard Audi setup?
#122
David8
David8
  • 431 posts
  • LocationBournemouth
Yes all standard brakes standard everything
#123
Get them replaced under warranty then stick red stuff in on the new discs
#124
Mattjj82
Mattjj82
  • 907 posts
David, have a search in the forum and see another thread running in the 8P section titled Red Stuff. Will tell you everything you need to know about the Audi brake setup
#125
SK-RS3
SK-RS3
  • 1,756 posts
Glad someone has had there rattle sorted mine is still raising its head every now and then mostly when engine had reached temp and started to cool again almost like metal Rotating against something gently but Audi 4 times have never found or heard it every fucker else has even at RS3 fest
#126
David8
David8
  • 431 posts
Sk it must be the variable valve sprockets on the cam it's a pain in the arse took me 5 months to source the problem have you got warranty ? If so just keep taking it back also what I did is every time I started my car hot or cold I recorded it with my iPhone to catch the sound and play it to Audi tech I will check out the red stuff thread thanks
#127
SK-RS3
SK-RS3
  • 1,756 posts
Ohhh yes extended warranty plus the issue has been logged with Audi uk so no way the nuggets are getting out of it if the engine goes bang.
Mine does it more in P when start it or give it a few revs it's not right I'm going to try and record it
#128
David8
David8
  • 431 posts
Yeah see if you can catch it on video mode on your phone they can't get out of sorting then
#129
David8
David8
  • 431 posts
Hi dead end !! Audi have had the car for three days it's been service fully new brakes on the front air con serviced they been all over the engine bay the tech has heard the intermittent acceleration sound or tapping noise on test drive he first said it sounded like an air leak but they can't find anything wrong with the engine and say there happy with it ? same problem as have had for past six months still no answer or idea to what it can be think I will just have to keep taking it back and hope it develops more and hope they can find it or maybe I should take it to someone else ?
Edited by David8, 11 May 2016 - 01:38 PM.
#130
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
mines does this, sounds like  tappit noise, does it randomly, give it a wee rev it goes away, not hampering performance.....
stage 2 8p 445BHP 518lb ft
#131
David8
David8
  • 431 posts
No it's not hampering performance it's just not a nice thing to hear when it's cost so much money and under warranty and also it sounds awesome when it's not doing it, I was hoping they would at least know what was causing ii but there you in sure if they knew what it was they would fix it
#132
David8
David8
  • 431 posts
Mine is exactly the same Steve give a Rev and it goes it's strange
#133
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
so is yours still doing it after everything thats been fixed?
#134
David8
David8
  • 431 posts
Yes had two master tech guys on it they have checked everything the only thing they chant check is start taking things apart like the turbo or the head and warranty company are not going to foot the bill for that so will see what I can come up with next I have a friend who said he could take a look he's worked on r8 and jags so I might give it to him and see what he thinks now
#135
David8
David8
  • 431 posts
I personally think it's a hydraulic lifter that is the problem but Audi won't top off to have a look unless they defiantly know it's that as warranty won't pay for them to do so same goes with the turbo if it's a turbo that maybe at fault they won't go into it they will only check around it that everything is fitted correctly so I'm going to get someone to take the top off a check the lifters turbo seems fine so it's not that
#136
*Dan*
*Dan*
  • 183 posts
Your issue then is if it is the lifters, trying to get Audi to do the same as they will stick to the same story as before. It really is a case of computer says no with most modern day main dealer techs.
#137
VCDS  can confirm lifter problems.If you check the injector pulse width when you have the noise then one or more will change a lot.The lifter won`t be opening the valve enough therefore there`s not enough air going into one or more cylinders.The ecu will pick up a rich mixture and alter injector pulse width to compensate.Main dealers should be able to do that.
Edited by 0120raptor, 12 May 2016 - 04:12 PM.
#138
David8
David8
  • 431 posts
They never mentioned it at all , I don't think they really want to know they took a look over whole engine bay and made sure everything was tight and no leaks and that's it
Raps Can I plug vcds in while driving as that's the only time it does it ?
#139
You can use VCDS while driving.If it is a cam lifter it shouldn`t make any difference if your driving or not.It would be purely revs related.
#140
David8
David8
  • 431 posts
It only does it when in drive and driving along it doesn't do it when it's in park or neutral and revving it, it sounds fine until you start start driving the car
Edited by David8, 11 May 2016 - 10:13 PM.
