They won't be interested in any warranty issues with discs & pads once you use aftermarket pads, I've been told.
I'm fine with that as I can get a new pair of front discs for £420. If I need to.
Hi there.
This is not strictly true. I had some Pagid R19 pads on my RS3 for a number of months. When the squeel annoyed me so much that I couldnt bare it i took it to Audi for them to put OEM pads back on. They found a fault with the brake system (the floating discs had moved) which was not pad related and they replaced the calipers, discs and pads at no cost to me.
Incidentally, this is the same issue i now have again nine months later. The floating disc on one side has physically moved and they cannot fit new pads as the gap is too small. They are again replacing the calipers, discs and pads on both sides.
I am seeking a full explanation from Audi UK as to what the problem is because this is not normal and is clearly a fault.
There will be a time when Audi wont remedy this so I want to know what the problem is and what they are going to do to solve it.
The car is a 60 plate and has done 50,000 miles.
