first remap apr stage 1
- - - - - apr stage1
114 replies to this topic
#81
So here is a question that may start a riot and with Wayne in this topic it could be fun, if it's already been done to death please tell me to piss off ;).
I really want to map the RS3, everyone says APR but..... With APR being an American company what's their real life experience of English fuel and tuning ability to deal with the difference? I, in no way doubt their tuning prowess and capabilities I am just curious as to how they get round this issue. Do they road test their maps in the country of sale using the available fuel to the customer and in real time conditions before sent into the public domain ect?
Are APR maps a full remap of the complete suck, squeeze, bang, blow procedure, ie increased valve timing to compensate for the increase in fuel pressure, inlet pressure, exhaust pressure and EGT's or is it a case of, up the turbo pressure and increase the fuel as we see so many times with tuning box's and 'remaps'. So many times you hear of complete head failure due to an increase in fuel and boost?
I would also include Revo and any other on the day remapers into this, as a company that can remap cars on the day of a show by a simple flash of the ECU with no on road/RR testing or driving results to me seems foreign coming from a background of remap road test, pull over and tweak, drive and continue until both parties (tuner and customer) are happy with the end result. Spending £850 for a simple ECU flash is out of the question for me until somebody can tell me otherwise . The problem is every car is different.
Which then leads onto the question. With an English based Audi specialist tuner like MRC who have years of experience on home ground, with great results (from what I can see) on their own maps be a much better choice?
They have their own map that is then tweaked and refined as a RR takes place and the car doesn't leave until they are happy with it (from what I can gather). Simply just doing a RR before and after tells no truths about the behaviour of the map, just the figures achieved?
There are pages on here on the merits of which map and ultimately it is your choice. I would suggest most on here went for APR as they have a UK wide franchise dealer network should anything go wrong and the results they have produced have been pretty much consistent across each application with optimum bhp and torque curve characteristics rather than just headline figures and have been good enough to make themselves open to communicating with the forum's members on here. Granted their communication could be improved but it is far better than what some have received from some of the tuners you have named, i.e. you don't here from them at all when you contact them. I would also say that given the number of UK APR tuned RS3's and TT-RS's they probably have the largest number of tuned 2.5 5cyl cars to their credit.
Whilst every car is different and I can advocate that on my own car and what it produced on an independent rolling road, like your OEM map the parameters can be set to a universal standard which will achieve best results and APR is like that as with MTM, REVO, ABT etc. I would query exactly how much more gain you would get from your car being individually tuned. Having done that on a B6 S4 with Revo back in 2005 when Mitch still worked there and they had a decent reputation, after they spent 8 hours tweaking their stock program and an independent rolling road I got 5bhp more and a 2% torque curve gain on a car that eventually did 385bhp. Would I feel the difference, I doubt it.
APR did or perhaps still do have a UK operation and their stock US map was adjusted for the EU spec ECU's emissions and fuelling. Also the Bosch ME9 ECU's are learning in nature so part of mapping them is removing their restrictors to allow them to modulate fuelling, intake pressure / temperature, timing, etc. to how you drive. For booker, the maps can be remarkably different depending on boost pressure used, fuelling timing etc. etc. so whilst the curves look similar how they arrive at the figures can be very different. Then throw in the debate on rolling roads and the wild differences you can have between them.
Ultimately JThornley you have choice and if you believe MRC are the solution for you then sincerely good luck to you for using them. The prospect of flat bedding my car from Newcastle to Banbury every time I had to have the map removed for warranty work or there was a fault was not palatable and the old adage is that appearances can sometimes be deceptive.
Just one of many MRC related stories I could give you; carbon cleaning and remaps on B7 RS4's was and probably still is a heated topic so one day a friend and I tested the theory out where he had a B7 RS4 saloon that with 30k miles on the clock that had been carbon cleaned and an MRC stage 1 remap with a Tubi exhaust fitted and I has a stock RS4 Avant with 55k miles on the clock that had not been touched except a cat back exhaust. Both of us had on the gauge half a tank of V-power, both recently serviced within 1k miles of the test. We did 4 rolling runs, 2 each way on a deserted dual carriageway in third gear from 1500rpm in third through the 8500rpm in 4th and on each run we were neck and neck bar a couple of cm's if one of us got a slight jump on the other at the start. Yet on MRC's dyno my friend's RS4 seemingly had 50bhp more than mine and more torque as well. Go figure.
I'm not knocking MRC because they are one of the few V.A.G. tuners out there that have been going as long as they have and they do know their stuff but they are not peerless and are still ultimately a business selling products for money.
Edited by P_G, 04 June 2015 - 09:12 AM.
#82
Vito
Vito
  • 1,084 posts
  • LocationPreston Lancashire
Brilliant Graeme, thats exactly what I wanted to say, couldn't write it all like that though
Posted Image
#83
Josh
Josh
    If it's got **** or wheels it'll lose you money!
  • 705 posts
  • LocationDerbyshire
P_G, a truly fantastic response to an ultimately political and difficult question. I stressed over how to word that up without 'upsetting the apple cart'.
I wasn't to sure if the map accounted for the RS3's learning ability and without going into to much of a story I saw a horror in the Focus RS world of a simple Revo show day flash and tbh, it put me right off. I've always like the personal aspect of a live mapping session. As stated a RR can be doctored to read pretty much anything they want it too.
I haven't heard of anyone having real problems with any of APR's remaps and I'm VERY glad you were able to verify and clear up the fuel issue as this was something that I was most hesitant about. An interesting story about the RS4 too I have always been a fan of them and never bought the carbon cleaning hype anyway. I had trouble getting hold of MRC to talk to anyway, it was just with them being an English company that grabbed me and something I have been used to in the past of live tweaking of a map ect.
Thank you very much for taking the time to explain things Graeme it is greatly received and with that it looks like we aren't going on holiday after all this year ;) haha.
#84
I agree
It's nice to read such an informative post from someone who has real world experience of these things.
Sent from my iPhone using Brembo
#85
P_G - thanks for that, very informative. The main reason I am edging towards Revo is the convenience you mention plus the confidence in a company I know and trust - my nearest APR dealer is some 50 miles away whereas the nearest Revo dealer is 10 miles away and is a VAG specialist who has serviced both Golf r32 and Golf r for me in the past.
I think the convenience and peace of mind I get from these factors will probably outweigh any minimal differences in the map and subsequent performance
#86
AudiRS3
AudiRS3
  • 612 posts
  • LocationLancashire
P_G - thanks for that, very informative. The main reason I am edging towards Revo is the convenience you mention plus the confidence in a company I know and trust - my nearest APR dealer is some 50 miles away whereas the nearest Revo dealer is 10 miles away and is a *** specialist who has serviced both Golf r32 and Golf r for me in the past.
let me know how you get on...im still undecided between the 2.....Revo seems to be a more potent map in comparison to APR's smoother power delivery! As it stands, Revos is £599 inclusive of VAT where as APR is £671 (Both include rolling roads, before and after).
#87
Will do! Not sure whether my knowledge is current but I understand Revo install the remap via the OBD port whereas APR have to remove and take apart the ecu - if so this is another factor tipping the balance in favour of Revo
#88
marshy
marshy
  • 801 posts
  • LocationDumfriesshire
Revo do advertise as doing it through the OBD port which is a big bonus.
With Revo you need an SPS so you can switch back and forward to standard or other performance settings.
I'm not sure about the 2.5 tfsi but Revo claim some wacky figures on the S3 2.0 tfsi which when dyno'd seem to fall 40 bhp short!!
I've had APR and Revo on 2 different cars both 265 bhp tfsi's and the APR was much more potent and aggressive.
The Revo 2+ left me wanting more and constantly logging with vcds thinking there was a fault.
For me it's 100 miles for Revo and 140 for APR.
If I was mapping there's only one way I'd go APR
#89
AudiRS3
AudiRS3
  • 612 posts
Whenever the ECU is removed....thats why panic starts.....imagine they crack the lid, or shear one of the bolts off and it gets stuck in the screw housing....ayy yii yaii!!  :unsure:
#90
I'd like to hear how REVO do this as the ME9 ECU is OBDII program locked so you can read through the OBDII but not program / upload to it so it has to be 'cracked' and reprogrammed to allow bi-directional data streaming. To date no one has actually been able to report how REVO do this without cracking the ECU. As for removing the ECU AudiRS3, APR franchisees are trained to be able to do this for APR staff as part of the franchise. The bolts have to be removed and replaced and the unit is opened and to date I have only heard of 2 occasions where this was not done correctly and APR coughed up a new ECU and programming FOC. At least it doesn't have to be sent off somewhere which some tuners talk about.
Edited by P_G, 04 June 2015 - 03:24 PM.
#91
Thanks for all the info guys, now I'm really f*cking confused!  :unsure:
#92
How so?
#93
I was edging towards Revo, largely on the grounds of convenience and prior dealings with my nearest dealer as mentioned in my earlier post, but recent posts from others are casting doubt on the validity of my knowledge and most members on here are firmly in favour of APR
#94
I wouldn't take it as casting doubt, just no one has had any evidence to demonstrate they have had a REVO can map via OBD. APR is well researched but if you can get REVO to do this for you then go for it.
Better still, if your local REVO agent has them, get them to put you in touch with other RS3 / TTRS owners who they've done and take references. Its what I did for my local APR agent who had done 8 RS3 / TTRS's
Edited by P_G, 04 June 2015 - 07:52 PM.
#95
Good advice, thanks - I will post developments  :)
#96
Just to muddy the waters even more, APR summer sale started today until June 30th with 20% off maps.
#97
More mud to the waters - according to two Revo agents I spoke to today, all Revo maps have been installed through the OBD port since November 2014 and both have done remaps on RS3/TT RS without any problems  :)
#98
Josh
Josh
  • 705 posts
Interesting Booker, who is your local dealer?
#99
My local dealer is Midland VW of whom I have previous - good - experience, the other I called was Vagtech in MK
#100
Josh
Josh
  • 705 posts
Revo seem a good choice to me but the fact everyone raves over APR on here must count for something ey? I really don't know what to do, same boat as you I think...
Also tagged with one or more of these keywords: apr, stage1
