Not sure if I've posted in this forum before ?,
If not I'm Jay, owner of the first APR stage III stronic mapped in the UK a few years back now.
Just to let you know,before I went to stage III , I was testing stage 1 and 2 maps for APR in Germany on the autobahns.
As I quite often drive to the UK , I would pop into Milton Keynes, get the car setup whilst the guys from APR USA were in the country and then drive back to Germany.
Later I started testing with stage III and since then I have done 98,100,102 octane map testing and now I'm on stage III + with engine re-build from Racing Developments.
I also have a racing DSG clutch and updates from TVS in Holland, as APR have no DSG maps for our cars.
It could be that to get the car to work perfectly, I will have to try TVS's engine software that they have been working on,as it's best that the TCU and ECU are working in harmony with each other.
Before any one ask's, I have no exact idea what power I'm running at the moment.
The car has been setup on dyno's before but we have found that it's far better setting the engine and dsg up on the road.Thank God for autobahns, lol.
I can say that before the engine build, power figures I have seen ranged from the early days 400 hp,535 lb/ft on stage II(Forge road intercooler) and with stage III, 560 hp on Vpower in the Uk to 620 HP on 102 in Germany. 100-200 kmh times came down to around 8secs stage II and from 6.4 sec to 6.1 stage III.Since then I have done 5.8 and 5.6 secs with the engine re-build.
I will have to do some more testing again once newer TCU software is on the car and if I go for a high boost TVS ECU map ?
As far as reliability goes.
The car has done 80,000 km now and was first tuned with 9000 km on the clock.
I've done 30,000 km with stage III with plenty of hard driving,although with stage III it's pretty hard to really thrash the car, even on the autobahns.
In the early days we had the normal problems with the speed limiter coming back in and an overboost problem,but these were fixed easily and quickly.
The clutch was changed at my request and not because it needed to be,though we did see that the clutch was slipping in launch mode.
When the engine was stripped, all parts looked perfect even after 17,000 km of stage III .
APR have always given great support,even if sometimes it takes a bit of time due to the time difference when the engineers are in the US.
Any way hope this helps those wondering about APR and maps in the UK.
