Sean, Ive received my pads today but what I didn't expect was to see that there is no shim or backing plate/material on the rear of the pad.
Did you run yours as they come or us a backing plate/shim of some description? I know from experience the lack of something on the back of the pad cause squeal?
Hi Matt
No mate, when I fitted the pads to my 8P there where no shims supplied with the DS Ferodo pads, however......
Like a fool I fitted the pads using the shims from the short lived Yellow stuff pads, thinking that they ‘needed’ a shim....
How wrong was I
instead of squeal upon braking, I had squeal upon no braking
What was happening was the Ferodo pads were slightly thicker than oem pads, so the addition of a ‘shim’ gave the new pads no where to back off, so they rubbed against the discs when the pedal wasn’t being pressed.
Soon cured though, took them removed shims and used Ceratec.
Car was quiet after that.
Same on the 8V too no shims and no squeal.
They’ll soon be going on the FL too.
Edited by T-800, 13 December 2017 - 05:08 PM.
