Spark Plugs
92 replies to this topic
Does anyone have the torque settings for the plugs to hand.
Closest i can find is 25 or 30 Nm but which one?
Here you go Rob.....
30NM it is
Thanks Sean
RS7 stock plugs are an upgrade, 12£ per plug on eBay
Wish I had managed to find them, just paid £320 for the 8 I needed for the RS7 at its service! Mind Audi were originally wanting £430!
Edited by P_G, 15 January 2017 - 05:21 PM.
red14
red14
  • 680 posts
  • LocationGlasgow
Duke, what mileage are you at?
Trying to work out the best time to change out things so I keep at peak perfrormance.
Mine were replaced at 28k (at remap) and plug coils a little later at 30k.
Red, currently at 53K miles. The plugs that I just took out looked fine to be honest. A bit Sooty around the electrodes but the gap was the same as the new ones.
Mine were last changed at 32K and I think that was the first time they had been done. At the time I got Audi to do it during a service as I asked them to check when they were last changed as there was nothing in the service book. When they looked there was nothing on Audi's maintenance record for the car to say they had ever been changed.
No real noticeable affect since the new ones were fitted so sticking to Audi,s 19K period should be fine for stock engines. Not sure about mapped engines though.
FYI on the 8V Audi are changing the plugs every 20k. They charged me £163 to S&F them, probably a rip off ;)
Audi charged me £170 to supply and fit so seeing as I got a set for £69 and fitted them myself that's £100 I didn't have to give the stealers.
As TX says 20k on the 8P and same on the 8V
If you source them online or from a TPS they are a straight forward thing to change yourself.....
2 Torx screws undone from the coil pack rack, then starting from the left hand side carefully un-clip each coil pack from its connector, then withdraw the whole coil pack connector rack towards you, if you've not got a coil pack puller then a cable tie or your hand will suffice......
Edited by T-800, 16 January 2017 - 01:52 PM.
You forgot the hall affect sensor Sean. It's on the same loom as the coil pack connectors. If you unplug this it's a lot easier to move the rack out of the way to work on the plugs. You can't miss it as it's right on the front of the engine. 1/2 hour job tops and that included a VCDS scan afterwards.
True Duke
However I've never felt the urge to unplug it, as the connector rail swings up enough for me to access the coil packs/plugs.
For anyone wondering as Duke says it's item 6 on the screen shot above...
Edited by T-800, 16 January 2017 - 04:17 PM.
True Duke
I've got these
However you can use these
Mattjj82
Mattjj82
  • 907 posts
Maybe I have thin fingers or I'm just strong but I pull them up by hand 😉😂
If I were mapped id recommend changing the plugs more frequently than Audi say as they last nowhere near as long 😉
Ha ha.... I used to, but once I saw the coil pack tools it was hard to resist
RS3JET
RS3JET
  • 357 posts
  • LocationSouth
I had my plugs changed at 20,000 by Audi and they charged me Â£170-00
Must be standard charge
Excuse the novice question BUT is a coil pack and spark plug the same thing? Or is the spark plug within the coil pack
Jay jay jay....
Matt ,
your just a roughy toughy mate ,
Hands of steel !
Jay I have a similar set up on my Daimler they have "extender tubes" that connect from the HT lead to the top of the plug
52 years old it is
Edited by Roy, 16 January 2017 - 05:57 PM.
Jay jay jay....
So the spark plug sits inside the coil pack?
Ive used a trim removal tool to lift the coil packs when changing the spark plugs  :)
Jay the coil packs push onto the spark pulgs from above !  :)
