Uprated rear anti roll bar
#121
Posted 05 September 2016 - 08:12 PM
#122
Posted 11 September 2016 - 07:45 AM
#123
Posted 11 September 2016 - 09:46 AM
I've had a set in the garage for over six months but they have not been fitted yet.
I have a set of coil-overs coming soon which once fitted will drop the rear ride height so I will fit the drops then to adjust the ARB pre-load correctly.
#124
Posted 11 September 2016 - 12:54 PM
I'm guessing it's not a major need otherwise suppose they would be on already haha
#125
Posted 11 September 2016 - 01:51 PM
I've got the 034 items:
sway-bar-end-links-motorsport-rear-adjustable-audi-8p-8j-tt-a3-volkswagen-mkv-mkvi-jetta-gti-r32-rabbit-034-402-4001-1.jpg 43.75K
7 downloads
Not essential really but some advantages:
Stronger, more articulation on the joints, adjustable for length so you can get the pre-load right.
But most importantly:
They look good:
Not that you can actually see them though:
#126
Posted 11 September 2016 - 04:33 PM
Back to the topic, how often should one lubricate the 034 ARB. Mine has been on a few months now and I was reminded of it when I was under the car last week. I really should have painted it before it went on. Nothing says more about a careful owner than the state of his (or her) undercarriage...
(in agreement with Duke3D above!)
#127
Posted 11 September 2016 - 05:05 PM
Good question Red. Mine's been on 18 months and I haven't re-lubed. It's well overdue and I do have some squeaking from the back although I am fairly sure it's my top mounts packing up. New ones waiting to be fitted.
Dunno, but I suppose once a year re-lube. Treat it like a yearly service.
Superlube is what is supplied with the bar and it's worked OK for me so I have a tube ready and waiting in the garage.
#128
Posted 17 September 2016 - 12:47 PM
I take it you only need to coat the black bushes inside and outside? Any recommendation on the original instructions on quantity or just smother them as I haven't got them (bought 2nd hand)Good question Red. Mine's been on 18 months and I haven't re-lubed. It's well overdue and I do have some squeaking from the back although I am fairly sure it's my top mounts packing up. New ones waiting to be fitted.
#129
Posted 17 September 2016 - 01:39 PM
The ARB brackets have grease nipples Jay. just use these to stop you having to drop the brackets and bushes off the car
#130
Posted 17 September 2016 - 02:18 PM
I've got to get under the car anyway for an oil change so was going to do the ARB too. I've bought a tube of that super lube so not sure how I'd get it from the tube into the grease nipples. If it's only an annual thing I don't mind doing it the "hard" way even though it's 4 boltsThe ARB brackets have grease nipples Jay. just use these to stop you having to drop the brackets and bushes off the car
#131
Posted 19 September 2016 - 04:15 PM
Edited by JayRS3, 19 September 2016 - 04:15 PM.
#132
Posted 24 September 2016 - 01:07 PM
Will report back more when I've had a chance to eat up some fast back roads
#133
Posted 25 September 2016 - 07:24 PM
Got under the car today and checked the condition of the bushes, dismounted the brackets. The bushes were bone dry since installing it in April. Re greased with super lube inside and out of the bushes and re assembled. Maybe annual is slightly too long for the maintenance on these.
Stripped my ARB brackets down today Jay based on your findings. I haven't re-lubed mine since I fitted it 18 months ago. Whoops, time flies when your having fun. Really hadn't even thought about them even though I had the lube in the garage.
Yup mine were drier than a 7 year old cream cracker on a warm day. Luckily the bushes appear to have survived so lubed them up and re-fitted.
Un-surprisingly the squeaking I got from the back suspension when going over speed bumps etc that I thought was the shock top mounts has stopped.
One thing I will change apart from lubing more often is to make up some covers for the grease nipples as they get covered in crap and need a good clean before you can use them.
#134
Posted 25 September 2016 - 08:19 PM
Pleased to hear. I may have some spare grease nipple covers if you'd like me to send them to you? I've yet to try them on mine yet but if they'll fit I'm happy to send you a pair.Stripped my ARB brackets down today Jay based on your findings. I haven't re-lubed mine since I fitted it 18 months ago. Whoops, time flies when your having fun. Really hadn't even thought about them even though I had the lube in the garage.
#135
Posted 26 September 2016 - 01:15 AM
Thanks for the offer Jay but I found some in a box of bits and bobs so I'm sorted.
#136
Posted 14 October 2016 - 09:11 AM
#137
Posted 14 October 2016 - 09:31 AM
#138
Posted 14 October 2016 - 09:38 AM
Is it the back trying to step out?
Other factors can reduce overall traction. Worn tyres, worn shocks, alignment out etc.
Generally I found the standard springs do a fairly good job but if you try hard enough you can exceed any limits.
I fitted some Eibach front springs and they have really upset the balance of the car as they are too soft and compression rate doesn't match the original rears. At the moment I am getting the rear trying to step out if I push too hard which didn't happen with the original fronts.
Soon to be removed and coil overs fitted should resolve this.
#139
Posted 14 October 2016 - 12:12 PM
Maybe I pushed harder then I used to without noticing it's a bend I do every morning on a national speed road just found it odd because never did it before.
I think I have it on the stiffer setting the second hole down towards end of the metal right ?
#140
Posted 14 October 2016 - 12:13 PM
Do you have any other suspension mods?
What coilovers are you fitting id like to do mine but never upgraded suspension on a motor so not sure where to start
