Uprated rear anti roll bar
144 replies to this topic
#141
Bilstein B16's sat in the garage waiting for me to get time to fit.
BTW the hole at the end of the bar is the softer setting.
#142
SK-RS3
SK-RS3
  • 1,756 posts
So this is softer setting Attached File  IMG_0883.JPG   116.93K   9 downloads
#143
Yup.
#144
SK-RS3
SK-RS3
  • 1,756 posts
🙈 ahhh this could be where I'm going wrong then
#145
Started to get a bit of creaking in the back again when going round corners and the rear seemed a bit soft. Got the chance to get under today and the grease brackets had worked there way loose which caused the bar to move quite freely. Re torqued these bolts to 20Nm, released and re torqued the drop link bolts to 40Nm.
I've had to do this more than once so perhaps the spec ratings aren't quite sufficient
Edited by JayRS3, 14 January 2017 - 05:09 PM.
