Posted 03 November 2019 - 11:54 AM
Had multiple compression tests and leak tests.. results come back as a brand new engine...
I've changed the high pressure Injectors also but they wasnt the issue so I have a set of Injectors for sale
#222
Posted 03 November 2019 - 01:02 PM
Anyones input will be appreciated...
How about going back to your tuner as a 1st port of call with your running problem ?
Posted 03 November 2019 - 01:34 PM
#224
Posted 03 November 2019 - 02:18 PM
Posted 03 November 2019 - 02:19 PM
#226
Posted 03 November 2019 - 02:23 PM
Done that 4 times this month. Hence why we have new Injectors. And 3 sets of different plugs..
I'm no expert but it probably a mapping issue especially as the turbo is quite large & your using it outside is designed zone as a daily drive.
As for the plug if there fouling/getting wet there either too cold a grade or the wrong type eg a shrouded race tip which won't self clean at low rpms instead of a projector nose type which will,or you have mapping issues.
The rub with the projector nose type are at high boost/rpms they may not be able to take the heat that well & melt up.
Posted 03 November 2019 - 02:27 PM
i use 7438-8 plugs but I have used the 37s before. Always went back to race tips in the endAnyone in here have used the ngk r7437-8 plugs?
#228
Posted 03 November 2019 - 02:41 PM
I have tried the denso ikh 0124 which Iroz recommend... they got wet on low rpm.I'm no expert but it probably a mapping issue especially as the turbo is quite large & your using it outside is designed zone as a daily drive.
Ive had the ngk7438-8 these also got wet...
I have now the ngk r7437-8 which have the longer projection of 3.0mm compared to the 8-8 WHICH are 0.5mm
The ngk7437-8 are good for street driving and self clean at low rpms.. doesnt seem to help so far. Although these plugs ate looking way better than the other 2 did....
Edited by Buchrs3, 03 November 2019 - 02:42 PM.
#229
Posted 03 November 2019 - 02:43 PM
#230
Posted 03 November 2019 - 04:25 PM
Mrc recommend heat range 9 aswell but I aint too sure....I'm gonna have the mapping changed.. and go from there
9s are even colder in heat range so will make the problem worst.
Most tuners can map a car for flat out use but low rpms & part throttle fueling is a skill.
I'm with Ben on this one.
#231
Posted 03 November 2019 - 04:30 PM
Yh booked into mrc now. Will need to tell them I drive low rpms aswell as on boost occasionally...
#232
Posted 03 November 2019 - 06:48 PM
You map to how the car needs to be so it will run properly with the hardware that is fitted.
How it drives on the school run will be down to the turbo once it's mapped properly.
Edited by RS3Dell, 03 November 2019 - 06:55 PM.
#233
Posted 03 November 2019 - 07:01 PM
I must say it's a screamer... it sounds jus like a supercar...
#234
Posted 03 November 2019 - 07:35 PM
You have to remember the likes of Hank at Iroz is just tracking the car for the 1/4 and 1/2 miles runs - it is not in use as a daily so the kind of set-up he is running is not going to do for anyone who wants to use the car on the street.
The tuning for an everyday car needs to take into account the range of different uses and conditions.
Hope you get it balanced out ok mate.
#235
Posted 03 November 2019 - 07:41 PM
#236
Posted 03 November 2019 - 07:51 PM
I have to say, I always thought that once the warranty (lol) has run down I would be getting MRC to breath on it - with all of the various issues people are flagging I am starting to think the APR route might be the better option?
#237
Posted 03 November 2019 - 07:52 PM
#238
Posted 03 November 2019 - 07:59 PM
MRC didn’t map buchs car though ?
#239
Posted 03 November 2019 - 08:01 PM
MRC is the place to go.Or Revo for that matter.
Revo never seem to live up to the hype.
#240
Posted 03 November 2019 - 08:05 PM
Oops - my bad. Or maybe I will follow the crazies and go down the JB4 route
