I'm sure I read somewhere that the OEM wheels need bolts with the rings on them due to the actual PCD of the wheels. Can't recall where though.
I have a feeling that this floating washer thing will get out of control!
I have never heard that oem wheels need floating washers. I doubt it very much as the PCD is exactly the same for hub and wheel, so not really necessary.
There are in fact two types of wheel bolt, well three in fact - fixed bolt, one with flotaing washer or collar and a 'PCD Variation' bolt.
The floating washer is loose on the bolt and can take up any machining differences to ensure a good fit and it allows more tightening force without ruining the wheel seats - especially now when all wheel shops use impact guns. For this reason, they are used by the better manufacturers - Audi MB and BMW certainly. These are often referred to as wobble bolts or security bolts.
PCD variation bolts still have a floating washer or collar, but there is a good few milimetres sideways movement of the collar around the bolt. These are used where some far flung maufacturers have PCDs a couple of milimetres 'off the norm' - I remember the older Alfas had a 98mm PCD when everyone else, and all the aftermarket wheels, were 100mm PCD
