RS3 rally car.
134 replies to this topic
Do you get brake squeal though??  :P  :P  :P  :P  :D  :D
Pat
Pat
  • 1,008 posts
That's an amazing reply thx a lot for that
I'm interested I hearing about the Haldex and would be very appreciative of any gems that my tuners are not aware of.
They have built many cars and their experience is amazing but not really this car of this spec ...and me been me I don't want leave anything to chance
This forum has many threads about the CV joints and prop bolts failing and needing replacement
I'm worried that these and splined shafts maybe std A3 parts and not up to big money HP and the R&D didn't really feature much in it's construction....
Anything uve come across or aware of please PM me with
Mine is going be a strange car when it's finished
Hopefully in a category all of it's own... all show and all go lol
Bronco
Bronco
  • 79 posts
  • LocationNorth Wales
Roy brake squeal out of this build would be like music to my ears right now. Cant wait to take it back for recalls.
Edited by Bronco, 14 November 2014 - 09:46 PM.
Pat
Pat
  • 1,008 posts
I tried get a new set of discs and calipers for mine to then sell on when the big units (prob R8) get fitted
All was good until Stoke Audi informed me that aftermarket pads had been fitted by previous owner and the sensor wires had been tied up..... So they wouldn't replace !!! Gutted
I will have lots of parts to sell soon inc if anyone is interested the MMI Head/face unit and the bose system and speakers
Most likely someone wanting to jazz up a std A3 will want most bits
Pat
Pat
  • 1,008 posts
Bronco
Bronco
  • 79 posts
The dash will need a good trim up to make it fit past the roll cage.
Bronco
Bronco
  • 79 posts
Steering column about to go on a diet.
Pat
Pat
  • 1,008 posts
What discs and calipers you thinking of both for weight and performance ?
Bronco
Bronco
  • 79 posts
Will run with the standard brakes and see how they go. Only allowed max 18" wheels so fitting anything bigger in will be a problem. The wheels for ralling are normally a bit thicker and stronger so space becomes a problem. On the plus side, it is much much easier to stop a lighter car. Will let you Know what it weighs when its finished .
Bronco
Bronco
  • 79 posts
Will need to fab some floor mounts for new pedals.
Bronco
Bronco
  • 79 posts
Bit random, sequencial box ready to go back in the escort.
Bronco
Bronco
  • 79 posts
Floor mount for pedals.
Bronco
Bronco
  • 79 posts
Pedals fit nice. Need to make foot tray to lift feet up.
Jmcnamee98
Jmcnamee98
  • 618 posts
Hello Big Bear, Had a look at what your at and sounds real good. There are plenty of big power 700bhp ttrs out there running fine on standard transmission components. We are using the manual box from the ttrs because dsg is less than ideal for ralling. The box will be fully stripped and all internals superfinished. Will probably superfinish the angle drive and CWP. I have little experiance of any Audi cars before but the components look well made when compared to subaru etc. Took the driveshafts apart for a look and the inner cv,s are real nice.Has there been any failures reported? The rally car will also be much lighter than a road version which helps with the strain of hard launch, also we will not have massive power thanks to the 32mm restrictor. The haldex is being controlled by the same ecu as the engine and is very trick. At the moment we are just putting back the essential components so that the new loom can be made up and then get her up and running.
Hi great project good luck with it. I have had O/S CV Joint driveshaft and transmission unit failure more details here;
http://www.audirs3oc...ning-to-others/
Vito
Vito
  • 1,084 posts
  • LocationPreston Lancashire
This thread is becoming more and more fascinating, can't wait to see the final result. :rolleyes:
Posted Image
Pat
Pat
  • 1,008 posts
Yeh seen this thread along with the propshaft one and it does concern me
Trying to source upgrades but without success yet
Bronco
Bronco
  • 79 posts
Are all of the propshaft failures down to the bolts failing or are the props breaking as well? Are the ARP bolts curing the issue? Also are the driveshaft failures happening on the inner, outer or both CV joints. I doubt that the shaft itself is causing issues. Big Bear there is a plan for uprating the drive axles if need be but was rather hoping that the stock items were good.
Bronco
Bronco
  • 79 posts
Sitting a long way back to get better weight spread.
Pat
Pat
  • 1,008 posts
Thx for that info
In all honesty I can't answer your questions regarding the failures as it's only what I've read generally on here and tbh I'm no real spanner man but I get by lol
Guess it's gonna be a floor it and see scenario if owt goes bang !!
Bronco
Bronco
  • 79 posts
Bit more done today, got the steering column in position at last.
