My timing chain rattles on start up as many do.I can now get it to do it at will but it has to be done in a specific way..I`m convinced it`s oil viscosity related along with time.If I drive the car to get water hot AND oil up to 95*C then stop the engine and leave car for 4 hours .Then at the next start let engine idle for a few seconds then gently rev to 2000rpm.Rattle rattle rattle.Now if I only leave the car for 2 hours instead of 4 hours it won`t rattle.I think that in the time the car is left standing with hot oil it drains out of the tensioner slowly Once the tensioner is full the noise stops instantly. When the engine starts it runs on the low pressure pump first then switches to the high pressure pump.I have no idea how long the switchover takes or if it`s time or temp related.
Car`s been in to Audi twice now just for this and all they`ve done is change the oil.It didn`t make any difference,still rattles.
Johnny G .This is your old car .I heard that you had the same problem .I`d be grateful if you could give me any info on what if anything Audi did.
I think the TPI 202899/2/2 only uses the high pressure pump all the time but when I mentioned this to Audi I got blank looks.I also get the impression that they don`t want to get involved with tensioner changes.
Apart from the above and possibly using a higher viscosity oil say 5w40 has anyone any ideas how to stop this awful rattle.
Sign In
Create Account
Back to top
View Garage
