Dell I hope you read all that mate !
Eibach Pros....
Posted 05 August 2018 - 05:37 PM
Posted 05 August 2018 - 05:38 PM
Right so this morning I tackled the rear springs.
Official Audi Elsawin says these can be compressed then removed, bollox not a chance!!
You need to pop out the plastic centre piece in the cup.
Screwdriver and gently prise the 4 tabs, it can then be removed from inside the spring.
Undo mag ride level sensor, located by 2 Torx screws on the arm.
Undo the anti-roll bar drop link where it sits in the arm followed by the strut bolt/nut and the outer hub bush /Bolt & nut
https://uploads.tapa...1617b902f9.heic
Have your second jack support the arm while you remove the bolts, a gentle tap gets them out.
Let the jack down a little and the spring will come out very easily again pay attention to the rubber fittings top and bottom.
Take off the rubber fittings and fit to the new spring.
Make sure the bottom one is in the correct position, thereās a recess for guidance.
Also make sure when you refit in the cup holder that you have the rubber locating pin in the hole.
Re-insert the plastic centre piece you popped out from the spring base/cup at the start, make sure the clips engage.
Once the new spring is seated correctly you can jack the arm back up enough to align the 3 holes, then insert the bolt for the drop link first, MagRide strut,then outer Bush / hub
I then jacked up the whole assembly to simulate a load and then tightened all three up.
You can also do the same if you put the wheel back on and allow the cars weight back on the suspension , however youād still need to sit the rear wheels on something to allow you the room to do this or you may have a four post ramp so even better
Reconnect the Mag Ride level sensor to the arm.
Check over everything and make sure you are happy.
Put the wheel on.
Edited by T-800, 05 August 2018 - 05:39 PM.
Posted 05 August 2018 - 05:45 PM
Iām allowing a few days for things to settle etc.
Iāll then be having alignment and carrying out a full mag ride re-adaptation so the system knows itās new default positions.
First impressions so far are good.
Very smooth and the ācrashyā effect of the OEM springs is no longer there.
Obviously Iāll reap the full benefits after the 2 processes above.
Drop currently is around 20mm.
https://uploads.tapa...f5d23b5a83.heic
Posted 05 August 2018 - 05:53 PM
Posted 05 August 2018 - 05:54 PM
T-800 nice write up matey, did you use spacers?
Edited by BenTTU, 05 August 2018 - 05:55 PM.
Posted 05 August 2018 - 06:19 PM
Posted 05 August 2018 - 06:25 PM
Posted 05 August 2018 - 06:31 PM
No donāt need them.Yes matey
Never felt the need either to be fair.
My Winter RS6 wheels are E47 and 8.5j all round so fill out the arches nicer.
Posted 05 August 2018 - 06:56 PM
Do those springs have a softer rate.? When you say they reduce the crashiness surely they are softer.
Posted 05 August 2018 - 07:14 PM
Honest answer Neil is I donāt know.Sean
I just know it now feels better when encountering rough / crappy roads
Maybe my view will change once the MagRide is recalibrated because when fitting springs is usually when you lose the definition between modes.
Although Iām expecting them to actually get better once itās done.
Posted 05 August 2018 - 07:25 PM
Everyone I know who has them always rates them.
The drop is very subtle too.
Posted 05 August 2018 - 07:36 PM
Itās the reason I chose the Eibach pros over all the others.
Roy.Yes i know whats coming next mate.šAlmost the same set up as a 8p just remind me to diconnect the Magride.šDell.Dell I hope you read all that mate !
Roy.
Yes i know whats coming next mate.šAlmost the same set up as a 8p just remind me to disconnect the Magride.š
Edited by RS3Dell, 05 August 2018 - 10:11 PM.
Posted 05 August 2018 - 07:45 PM
Just checked on their website.The springs are progressive so should feel softer over small bumps.Honest answer Neil is I donāt know.
Posted 05 August 2018 - 08:02 PM
Thought we would have pictures of new discs fitted by now Neil
Posted 05 August 2018 - 08:04 PM
Tomorrow. It`s going dark now.Thought we would have pictures of new discs fitted by now Neil
Posted 05 August 2018 - 10:16 PM
SeanDo those springs have a softer rate.? When you say they reduce the crashiness surely they are softer.
Neil.
If Eilbach know what Bilstein know they are a softer spring rate as the oem ones are over sprung.
The B14 are softer on the springs but a big improvement on the damping rates.
Posted 05 August 2018 - 10:25 PM
DellNeil.
Is the B14 springs as well as dampers?
Posted 05 August 2018 - 11:19 PM
DellIs the B14 springs as well as dampers?
Neil.
The.B14 are.a coilover kit (springs/dampers) without the adjustable damping like the B16 mate.
