Secondary Decat Pipe Fitting
Posted 21 April 2016 - 04:29 PM
Posted 21 April 2016 - 09:29 PM
Posted 21 April 2016 - 10:05 PM
Hmm... Need to find a local garage then to do it instead of main dealer.Jay mine past MOT with second cat bypass left on, was not a problem
Posted 22 April 2016 - 08:21 PM
All fitted, hardest part is getting the top nuts out...
Definitely a worthwhile mod..
Posted 22 April 2016 - 10:35 PM
Posted 24 April 2016 - 06:54 AM
I'm in Rochester I haven't got an issue travelling there if saves the agro of swapping.Jay don't know where you are in kent, but I used just MOTs in Tonbridge
Posted 24 April 2016 - 09:44 AM
For mk1 but isn't going to be too far if not the same for mk2. Courtesy of John.
1) The secondary-catalytic exhaust pipes are different; one straight and one bent: the straight pipe is fitted to the 'passenger' side of the car and the bent pipe to the 'driver' side
2) Each of the secondary-catalytic converter/exhaust pipes are connected to the downpipes with three M8 nuts and to the rear exhaust silencer with sleeves that are fastened with two captive bolts and nuts
Note: The secondary-catalytic converter/exhaust pipe(s) have three M8-studs fitted - and as Audi have been sufficiently thoughtful to use mild steel nuts to these mild steel studs then more than likely your nuts will have seized onto the studs; mine had at 3000 miles
REMOVAL:
3) Use an M13 ring spanner and release the nuts from the straight/nearside pipe; don't worry if the studs shear/break as you can drill the secondary-catalytic converter/exhaust pipe flange a 'clear' M9 diameter later
4) Release the 2-bolts securing the rearmost exhaust pipe sleeve (no need to remove the nuts just release so as to release/rotate the sleeve) and pull the sleeve toward the front of the car - the secondary-catalytic converter/exhaust pipe is now free to remove
5) Pull the secondary-catalytic exhaust pipe toward the back of the car and remove; store safely
CAUTION: DO NOT contaminate, touch, whatever, the core of secondary-catalytic converter
6) Remove the gasket and store safely
7) Repeat exactly the same process on the bent/offside pipe
8) Carefully clean both gaskets; if intact there's no reason why they can't be used again; alternatively, buy two new ones
REFIT:
9) Apply a thin smear of exhaust gasket sealant to one 3-pin gasket
10) Fit three M8 x 30mm long setscrews - apply as much Copperslip to the setscrew threads as you can - to the 'offside' downpipe flange and fit the gasket
11) Apply a thin smear of exhaust gasket sealant to both ends of one exhaust pipe sleeve and fit the sleeve to the by-pass pipe: DO NOT tighten at this stage
12) Assemble the by-pass pipe to the M8 x 30mm long setscrews at the downpipe end and loosely fasten with M8 spring washers and M8 nuts. Slide the exhaust pipe sleeve over the exhaust silence pipe making sure the sleeve is central over the gap between the pipes: DO NOT tighten at this stage
IMPORTANT: Make sure to rotate the bend in the pipe to the ###side
13) Nip the 3-setscrews/nuts at the front end
14) Nip the 2-bolts/nuts at the rear end
15) If all looks properly aligned tighten all 5-setscrews/bolts/nuts
16) Repeat exactly the same process on the straight/nearside pipe
17) Once done fire up the quattro and allow to warm through: check for exhaust leakage while on engine 'idle' and if all ok take the car onto the road and allow the engine to come up to a normal working temperature during which time the sealants will 'cure
I thought I recognised 'some' of them words, Jay; happy here that it was of use
Posted 24 April 2016 - 11:02 AM
Posted 25 April 2016 - 03:35 PM
Posted 25 April 2016 - 04:30 PM
Hi John hope your good
Not as good as I was, John, thank you; but will be OK, surgery (robot-assisted laparoscopic radical prostatectomy) imminent: PM sent...
Every male here needs to be aware of that nasty little gland hiding under yer bladder...
Edited by 45bvtc, 25 April 2016 - 04:53 PM.
Posted 03 August 2016 - 02:04 PM
Posted 03 August 2016 - 02:10 PM
Posted 03 August 2016 - 02:19 PM
Posted 03 August 2016 - 02:32 PM
Posted 03 August 2016 - 02:34 PM
Edited by monopole, 03 August 2016 - 02:35 PM.
Posted 03 August 2016 - 02:39 PM
Monopole have you fitted the milteck secondary downpipes on your exhaust
Posted 03 August 2016 - 02:43 PM
Posted 03 August 2016 - 02:49 PM
Posted 03 August 2016 - 02:54 PM
I'll pay particular attention to the start up and post back whilst I'm sat in the car 👍
Posted 03 August 2016 - 02:58 PM
