I just removed my miltek secondary decat pipes.
Overall the decats are louder across the range but the low rpm pops n crackles are a little muted.
The deeper/bassy tone of the oem sports exhaust is more high pitched with the decats. I prefer the deeper tone hence went back to stock.
Someone mentioned the turbo spool.. I can hear the turbo spool just as much with the oem exhaust.
What I would like to try is disable the exhaust flaps. Unfortunately the obdeleven mod for the exhaust doesn't work any longer nor is the long coding working.
Of course it spools anyway if it works but faster with less restriction, pure math. Take the first cat off and replace it with a racecat or none and it will spool even faster of course but if you not feel or hear anything then its no problem for you
