Jmcnamee98,
The jury is still out on the new front discs from Tarox, I got the first set off the production line and they are too thick (I did not mike them up but I would guess 0.5 - 1.0mm oversize). I really struggled to get the pads in (Pagid RS29) and those pads has never been out of spec before and I tried all 8 pads in each available slot after fitting the discs and torqueing up the calipres.
Once fully home the binding was not very heavy so I carried out 10 slow speed brake applications and it seemed OK, I really did not want to sand the faces down on my £400 brake pads! I did about 5 road miles with the highest speed of 40mph and kept up the gentle braking, when I got home they discs were warm but not hot so I left it to cool fully.
4 hours later I went out for the evening and got up to 70, it sounded like the front wheel bearing were knackered and I got a shaking of the steering when cornering and some pad knockback as well, I drove the rest of the way there and back below 40 (approx 25 miles).
I took it out again this afternoon and did some higher speed brakes runs with light pedal pressure and apart from the "wheel bearing noise" all seemed OK. I can hear the grooves doing their job at slow speed but if this "wheel bearing noise" (could even be an aerodynamic issue of the cooling slots) does not seriously improve I will be taking them off again.
I dropped Tarox an email yesterday before the higher speed run to let them know I have them fitted now, I will give it till the end of this week to decided how I proceed and keep you and Tarox posted.
TBH, if a AP fully floating disc and bell was available as a drop in replacement without having to change any brackets or remove the back plate I would not have looked after further
I would be interested to hear about your 2k kit as well please.
