My RS3
391 replies to this topic
#381
Renga
Renga
  • 149 posts
  • LocationSweden
I really would like the cupholder i use to have instead of the card holder is possible to do that?
Where did you get the Cigarette lighter delete?
I also have a bad rattle of my flywheel, should be worried and replace it?
https://player.vimeo...video/237562528
Edited by Renga, 06 September 2018 - 07:49 AM.
#382
StephenG
StephenG
  • 145 posts
Two great little mods, I would like those very much, particularly as the surround on my cig lighter is damaged.
#383
you can retrofit the cup holder but you’ll need the front plate of the card tray as the cup holder is only a square. Plenty of information online about this retrofit however they did remove this option as if you have a spillage so close to the RSNE then you may have some issues.
That noise definitely sounds like your flywheel needs to be replaced like mine did. Probably find it’s split in two places like mine which is the cause for the rattle.
#384
Stephen.
Heres the part No for the 12v shocket to replace the cigarette lighter,that is an old price by the way as its £30 inc vat mate.
Attached File  IMG-20180822-WA0049.jpg   75.16K   19 downloads
After reading the thread on the forum about the DV+ I thought I’d give it another go especially as I’m running more power this time round. I had one on my previous S3 (stage 1) and wasn’t that impressed.
Time will tell.
#386
Renga
Renga
  • 149 posts
  • LocationSweden
There is a suggestion how to improve it on the "2.5 TFSI Tuning" on Facebook  :)
#387
Quattro
Quattro
  • 416 posts
What’s that? Fit the standard part back on?
That’s the best improvement.
#388
looch
looch
  • 194 posts
No complaints here from using it
#389
Arkious
Arkious
  • 222 posts
  • LocationSouth Shields, North East
I’ve had one fitted for about 6 month now and had no issues. It does have a more ‘on-off’ feeling too it when driving but I like it.
Seems to give a better sound with the 034 intake too 👍🏻
#390
Yes mate already seen that and prepared to do it if I don’t notice anything.
#391
Drill the centre piston to 2.5mm and add a washer under the spring for a better seal.
#392
Arkious
Arkious
  • 222 posts
if you decide to do that let us know what your thoughts are pal, first I have heard this but makes sense
