17kg saving in unsprung mass from mostly over the front of the axel will make a HUGE difference. How anyone can say otherwise is astounding.
Maybe go strap 17kg of lead in your engine bay and go see what happens, if you feel otherwise.
Whether or not it's the same set up is another issue and all I see are assumptions in the replies. Lets try just dealing in fact and if you don't know why bother posting?
peazz, it's not a silly question at all, was thinking the same thing myself.
Just want to get a few things clear here. Unsprung mass is not what's in the engine bay.
If you can feel 17kg of difference under the bonnet you've got the sort of sensitivity that would notice the difference between and empty and full fuel tank, carrying a quarter of a passenger, having some shopping in the boot, etc. If you can fair play, but I don't believe you. Of course the clock can, in minuscule amounts. If stripping weight is your thing, also fair play.
17kg is just over 1% of the car's total weight. If you think this will make a difference, I'm astounded.
I've spent most of the last 18 years trying to or winning national kart championships. Being above the minimum weight is critical. However, removing just over 1% of the kart's weight would lead to zero anticipated improvement, based on thousands of laps of testing. Even moving such a small amount of weight on the chassis would do nothing.
So what logic are you using to predict that 1.1% saved would make an obvious difference?
Consider that with no restrictions, one way to remove understeer would be to give it front downforce - the exact equivalent of putting more weight over the front.
You don't understand understeer, do you? Or certainly what's causing it.
Peazz, would love to see it done. But also think you'd be completely mental. And it would require so much engineering to make it work that it is a total no go.
