Coilovers
67 replies to this topic
Jk911
Jk911
  • 222 posts
I have the exact same sentiments. Have the KW V3s & they not nearly as low as I'd liked!!! All round drive/handling is Superb!!!! -but if its stance you after the KW V3s wont be the answer
What settings are you using front and rear?
Just got my kw v3 fitted today ( thanks rs3del) I'm running the recommended settings for a week or so to see how it feels.
jk911 if it rubs over speed bumps it needs rising up 10mm mate  :rolleyes: & i fitted them on my birthday !
Jk911
Jk911
  • 222 posts
Car feels so much better than oem setup , I'm going to give it a week then play around with height and settings 😎
Looks so much better than oem too. The real surprise isn't the roadholding, you would expect that to be improved with a sports suspension package, but the ride - it is so much more supple and softer than standard
Jk911
Jk911
  • 222 posts
It's definitely firmer than oem but with non of the crashing and banging if that's makes sense.
As promised photos of mine as reference: Back set at 640mm, front at 636mm
Attached File  IMG_0083.JPG   80.48K   14 downloads
Attached File  IMG_0085.JPG   73.58K   14 downloads
Attached File  IMG_0087.JPG   81.76K   15 downloads
Attached File  IMG_0088.JPG   76.04K   15 downloads
Special multi coloured pain effects courtesy of Highways Agency.
Mattjj82
Mattjj82
  • 907 posts
Thanks Duke, don't you just love the roads this time of the year 😩 hope you washed after
I'm sitting a little lower at the rear than you I think.. I get the odd rub but it's only just touching the arch liner felt. on setting 2 at the rear so going firmer may help but I'm going to see if I can mod the liner slightly to stop it as don't want to adjust and change the ride height really
  • 11,963 posts
The joys of a black car
