RS3 brakepads
123 replies to this topic
#101
The Wire is embedded into one of the pads.....
So you'd need to snip it off and solder to the EBC wire then heatshrink or tape up.
#102
Caney
Caney
  • 257 posts
  • LocationWarwickshire
So it is possible to just disconnect the old sensor and reattach to the ebc pads?
Sent from my SM-N920C using Tapatalk
cut the wire off the oem pad with connector attached,cut off most of the wire with connector on ebc pad then solder the oem wire and connector onto ebc pad.
2018 NARDO RS3 SPORTBACK MRC STAGE 2 520PS/705NM0-60 3.19 SECS/0-100 7.06 SECS
#103
R16cck
R16cck
  • 296 posts
  • LocationManchester
Hi guys, my EBC redstuff front pads have arrived, looking forward to getting them on. For those that have run these pads for a while, how have you found them? Any signs of additional disc wear that you haven't expected? And how many miles have you been running them for?
Nardo Grey RS3 with high gloss black styling pack
#104
I`ve had mine on now for 4K miles.Never a squeal ever.Virtually no dust,no vibration.Discs look like new.What more can I say. I see your near me (Bolton) .Try mine if you like .
#105
deepspacemillar
deepspacemillar
  • 376 posts
I've ran them for nearly 10k miles after 10k miles of original pads.
I get small amounts of squeal briefly on the first few bits of light braking on cold starts. If you hoof the car about, as the brakes heat up you'll start to get shuddering and some squeal from right side. This is not the pads fault but the discs and the copious amount of compressed dust stuck in the disc.
Anyhoo, the pads are great - quiet, very little dust, no fade, better feel IMO. I've not noticed particularly increased wear
#106
R16cck
R16cck
  • 296 posts
That's great guys. Thanks. Will get them on on the weekend
#107
If you've got the rears as well you'll need to use VCDS to retract the winder behind the piston, then once retracted the piston push back tool can be used to push the piston back in, otherwise the newer rears may not fit in the gap left by the old pads.
Edited by T-800, 31 January 2017 - 07:58 AM.
#108
Hal
Hal
  • 253 posts
Here is one thing where Mercedes is more forgiving than Audi - putting rear brakes into service mode is done on the steering wheel by the user on the Mercedes.
Insisting on using the VCDS by Audi only encourages all the bad work arounds that get onto the internet.
#109
Yeah there is a work around but not one I'd like to suggest on here.......
#110
R16cck
R16cck
  • 296 posts
Hi guys, I finally changed my front pads for EBC redstuff yesterday DP31513C . This morning I was having a look at the disc and noted that the most outer part of the disc had developed a lip (see pics) thus indicating that the pad is slightly too small. Anyone else with EBC redstuff have this issue?
#111
You'll get it because the oem pads don't go right out to the outer edge, so it doesn't get swept by them.
#112
R16cck
R16cck
  • 296 posts
Ok, thanks. Strange that I only noticed that lip after fitting redstuff yesterday. Then again I don't think I paid much attention to the discs before!
#113
Most don't notice it and it's not an issue I feel......
You'll get a similar 'lip' developing over time on the inside nearest the spider too.
They'll have set the angle of the Caliper & pads so that maximum swept area is achieved without the pads going past either radius edge.
#114
R16cck
R16cck
  • 296 posts
Great, thanks Sean. Appreciate the reassurance.
#115
How do you find the Redstuff by the way ?
#116
R16cck
R16cck
  • 296 posts
Only a day in so not fully bedded yet but even now I have noticed significant improvement in stopping power. No squeal I'm looking forward to seeing what they're like after a few hundred miles. How about you?
#117
Oem pads here with zero issues.
#118
RS3ER
RS3ER
  • 190 posts
  • LocationLONDON
Give it time 🙈 T-800 must be driving like a fairy no brake squeal 😂
√ΛƓ ƇΛИ ṖŔᎾ √② + √ƇDS ĤƐӾ ИƐŦ + √ΛS ᎾDĪS ⑥①⑤④
#119
Matd
Matd
  • 87 posts
Ive had no problems since having my new round discs and putting my redstuff pads on. i havent been for a proper hard B road drive yet so will see what happens after that.but so far so good. Nice and sharp.
#120
Give it time T-800 must be driving like a fairy no brake squeal
Well I'm not standing on the brakes at the very last minute all the time.
But then again I came from a Mk 1 RS 3 that squealed like hell.
