Suspension upgrade
Posted 11 December 2015 - 06:47 PM
The rear I dropped 10mm setting 3 but after a run the rear has settled too low.
Ride is better than stock on 3 and the front adjustment is very easy but the rears more difficult.
Posted 12 December 2015 - 08:50 AM
I would have said the rears are easier to adjust the rebound setting dial and the fronts are more difficult as you can't really see what you are setting them to whereas on the rears you can see the red dot marker. Seemingly until a year or so ago Bilsteins never had marker points at all, pure guesswork!
Edited by P_G, 12 December 2015 - 08:52 AM.
Posted 12 December 2015 - 11:40 AM
Been out this morning and raised the rear 10mm which has put it back to my original 10mm drop.
When it had settled it was 20mm lower!
Just need to find some 8mm h&r hubcentric spacers at a decent price.
Posted 12 December 2015 - 02:17 PM
Posted 12 December 2015 - 04:20 PM
Found them here
http://www.amazon.co...2/dp/B005K8VNEO
Or with bolts
http://www.amazon.co...8qGL&ref=plSrch
Posted 12 December 2015 - 04:48 PM
Posted 12 December 2015 - 05:13 PM
Pretty sure this was the part number of the ones I had on my S3. They should be same fitment 5x112 and 57.1 bore although it does say on that advert no centre alignment.
I'll keep you posted.
Posted 12 December 2015 - 05:32 PM
Posted 12 December 2015 - 08:42 PM
I have 10mm hubcentric spacers front and rear. Ideally I would like 5mm at the rear and lower it another 5mm but 10mm is the smallest hubcentric I could find
Posted 12 December 2015 - 08:49 PM
https://www.dpmperfo...lt-thread-14x15
I've messaged Damian to see if they fit the RS3 as they're only listed for A3/S3
Wheel fitment is the same so can't see why not.
I'm sure when I researched last time H&R were the only ones to make a 8mm hubcentric
Edited by marshy, 12 December 2015 - 08:51 PM.
Posted 12 December 2015 - 08:59 PM
Posted 12 December 2015 - 09:02 PM
Posted 12 December 2015 - 09:24 PM
Posted 12 December 2015 - 09:31 PM
Posted 13 December 2015 - 04:14 PM
Posted 13 December 2015 - 04:29 PM
Posted 13 December 2015 - 04:54 PM
I'll run it for work this week then lift the rear slightly.
Posted 13 December 2015 - 05:17 PM
Posted 13 December 2015 - 06:23 PM
Looking good pal, I'd lower the front 5 m, I don't think it would affect ride with the bilsteins, as your on a soft setting
5m might be a little too much Sonny, but I get your drift
Posted 13 December 2015 - 07:26 PM
