Swap it for the S6
RSQ3 caliper on MK 1 RS3
#81
Posted 05 September 2015 - 07:45 PM
#82
Posted 05 September 2015 - 07:47 PM
I've changed phone numbers and moved house so Audi can't find me when they want it back
Sent from Cyberdyne systems
#83
Posted 06 September 2015 - 06:42 PM
So it's 17.5 for bracket thickness and 4.5/5mm gap between disc and mounting bracket
I've done this by centralising the 8 pot on the RS disc, then placing the bracket on the caliper.
The 2 bracket to hub mounting nuts are 55mm long.
Edited by T-800, 06 September 2015 - 07:01 PM.
#84
Posted 10 September 2015 - 09:28 PM
Will soon find out, all scheduled for fitting on the 22nd with new pads front and rear, new braided lines and some other additions to the car. Looks like my calipers will be here on Monday and hopefully the brackets later in the week going by the delivery time you had.
BKS have given me the bolt dimensions which are essentially R8 caliper mounting bracket bolts.
Edited by P_G, 11 September 2015 - 07:47 AM.
#85
Posted 10 September 2015 - 11:02 PM
#86
Posted 16 September 2015 - 05:55 PM
Calipers are here, they are proportionately some size when off the car. Just waiting for the mounting brackets which are now somewhere in the UK, so hopefully tomorrow or Friday for those.
#87
Posted 16 September 2015 - 06:30 PM
C,mon.. Someone hurry up and fit these to a car will ya!
Sean can't you pop over to that long stay car park where Audi have left your car for the last few months whilst pretending to fix it. Take your spare keys, fit the callipers take it for a test drive and let us know how they are before dropping it back.
Audi will never miss it for a few hours
#88
Posted 16 September 2015 - 07:15 PM
#89
Posted 16 September 2015 - 07:22 PM
#90
Posted 16 September 2015 - 08:23 PM
#91
Posted 17 September 2015 - 11:57 AM
Brackets have arrived, ready to rhumble. I wondered how BKS justified the price however they are sizeable precision German engineering mono block machined pieces.
Edited by P_G, 17 September 2015 - 11:57 AM.
#92
Posted 17 September 2015 - 12:04 PM
#93
Posted 17 September 2015 - 12:11 PM
They felt heavier, haven't put them on the scales. So that's approx. 7kgs per side as IIRC the package weight of the calipers was 12kgs. I wonder how heavy the OEM set up is and how much unsprung mass I'm adding?
#94
Posted 17 September 2015 - 12:52 PM
#95
Posted 17 September 2015 - 03:47 PM
'After much trial & error (not to mention spend) he retained his TT-RS 370mm OEM discs and added the RS4/8-pot caliper which only added 0.5kg weight per corner (for those interested in weight issues).'
http://www.vagoc.co....read.php?t=5582
Admin remove the link if not allowed I'm just crediting the info.
#96
Posted 17 September 2015 - 04:43 PM
I don't know why Audi didn't put them on in the first place.
#97
Posted 17 September 2015 - 05:24 PM
It's the pads that cause the noise and the pad friction surface fixing rivets that trash the discs.
Is there any guaruntee the pads available for those lovely 8 pots will be any different ?
#98
Posted 17 September 2015 - 06:01 PM
To me the difference was a lot more confidence inspiring.
#99
Posted 17 September 2015 - 08:07 PM
I ran Porsche Big reds for years on my modified S3's, so not adverse to the benefits, although I don't miss the costs!
I wonder if the 8V master cylinder arrangement is sized/ ported differently to suit, which might also affect how they feel to the user.
#100
Posted 17 September 2015 - 08:49 PM
Yeah that's one of the threads I read before taking the plunge......
Do you think the OEM discs will deal with the 8 pots well I'd be worried they'd heat the chocolate discs or maybe 8 pots wont have to work as hard and generate as much heat as the 4 pots I have no idea.
Also found these though that look interesting PPH RS3 brake cooling ducts;
https://translate.go...h-motoring.de/
