Car is almost undriveable - I seem to have lost four wheel drive
64 replies to this topic
  • 1,659 posts
U not tempted with the RS3 8v muzza ?
I've started to get all the symptoms of a failed Haldex pump: wheelspin, poor performance, jerky gear changes and additionally I get the smell of burning clutch when using full manual changes and driving hard. I've scanned the car but there are no error codes but there is definitely symptoms of a pump failure.
Has anyone else had the situation that VCDS doesn't report an error but Audi have confirmed Haldex pump failure when they have checked the car?
I have extended warranty but I really don't want Audi to tell me there is nothing wrong with it if I put it in for them to check if all they are going to do is scan it and then charge me for diagnostics.
When mine had it there were faults logged in vcds.
Sent from Cyberdyne systems
matty779blue
matty779blue
  • 45 posts
With mine there were no faults logged. Test drive confirmed no rear wheel drive and diagnosed by engineer
I too had extended warranty so just the £250 excess.
My local dealer is pretty good and wouldnt charge me for diagnositics until they had found and solved the fault.
Edited by matty779blue, 28 September 2015 - 02:57 PM.
Cheers Matty. Thanks for confirming. I better get mine booked in and see what happens.
marshy
marshy
  • 801 posts
  • LocationDumfriesshire
I've joined he 2 wheel drive RS3 club now!
Didn't realise how much the rear was used especially in these wet conditions.
Oh well at least it's still in warranty.
Welcome to the OC marshy
2 wheels good, 4 wheels better
I've got the situation of having Haldex pump logged on VCDS and then when taken to Audi they've said nothing's on the system. This has happened twice now. Think they just reset the car to avoid any replacement
Edited by JayRS3, 09 November 2015 - 01:57 PM.
marshy
marshy
  • 801 posts
That's mine and it comes back within a day or two when deleted.
The traction light flashes at junctions and even when dropping a couple of gears to overtake!
It's a bloody nightmare.
Attached File  ImageUploadedByTapatalk1447078420.834533.jpg   420.34K   11 downloads
Mine although haven't really noticed the traction light coming on
Edited by JayRS3, 09 November 2015 - 02:08 PM.
marshy
marshy
  • 801 posts
You can't be driving hard enough
When mine went the car turned into a right handful
marshy
marshy
  • 801 posts
I know what you mean Sean
I went to overtake and when I went it was all over the place!
It was that bad it felt like the car was going to go sideways!
Let's say the wife wasn't happy and said its not safe.
Ah Kev so you have same as Josh then......... The passenger speed limiter
marshy
marshy
  • 801 posts
Not very often don't we all?
Josh
Josh
    If it's got **** or wheels it'll lose you money!
  • 705 posts
  • LocationDerbyshire
She's a pain in the arse for it 😂 Always telling me off...good job I put that extra sound proofing in the boot. Now people outside can't here her shouting...😂😂
Do what I did.......... Get her a runabout
No wait, scratch that....... It'll just empty your pockets like the TT did to me although there's a certain satisfaction in fixing things yourself
  • 1,083 posts
What's going on with the mileage in Marshy and JayRS3 VCDS screen shots.
The same fault, same frequency of occurrences @ the exact same mileage?
