Car is almost undriveable - I seem to have lost four wheel drive
Posted 30 June 2015 - 04:05 PM
Posted 30 June 2015 - 09:35 PM
Posted 30 June 2015 - 09:39 PM
Sent from my iPhone using Brembo
Posted 01 July 2015 - 08:10 AM
I had exactly the same problems with mine whilst still in warranty. Happened once then went away. Couple months later couldn't stop the b**stad wheel spinning on any pull away. It was the haldex pump. A reasonably simple fix. In the end.
Not so bad then. Audi Stansted did say that they had never seen an issue with the Haldex control unit or gearbox.
What sort of money is a haldex pump fitted as Audi cannot get me in for another week. If its an easy job then I could get it sorted at local garage.
Matt
Posted 01 July 2015 - 10:11 AM
Matt
This will be covered under warranty as its an item which cannot wear due to driver error...so they have to replace it....
Unless you put the gearbox in Reverse at 70mph....
Good luck!
Posted 09 July 2015 - 10:40 AM
RS3 8V | RS3 8P
Posted 09 July 2015 - 10:59 AM
Had mine done at 27,000 early i know, but i had it done along with brake fluid / S-Tronic & filter changes............
Like to keep the car running 100%......... 1 less thing to worry about.
Posted 09 July 2015 - 11:05 AM
My car's only done 20k, my 2013 service book says the haldex fluid should be done at 30k.
Car's in the dealer as we speak getting it sorted, will post back later today once they get back to me.
Posted 09 July 2015 - 11:24 AM
Posted 09 July 2015 - 04:09 PM
Car is fixed. It was the haldex oil pump that had failed. Replaced under extended warranty.
Posted 09 July 2015 - 04:38 PM
Always good to know about good experiences with warranty companies...
RS3 8V | RS3 8P
Posted 09 July 2015 - 05:37 PM
Mines the same, just got it back but they've had to order the pump in, going in again next week to get sorted, under warranty too.
Mine had the 5 year box tiicked and is in warranty until March 2018.
Edited by Muzza80, 09 July 2015 - 05:38 PM.
Posted 10 July 2015 - 07:57 AM
Hi it was a one year extended Audi warranty which cost £538.16 carrying a £250 excess.
Roadside assistance excluded
Posted 14 July 2015 - 06:11 PM
Have exactly the same issue after replacing my tyres. In fact, I visited today to make my first ever post on the forum to ask for advice!
Looks like I'll be taking a trip to Audi...
Posted 16 July 2015 - 08:57 AM
Posted 16 July 2015 - 09:02 AM
Sent from Cyberdyne systems
Posted 16 July 2015 - 10:27 AM
I wonder if that's the same noise as my passenger side ......?
I reported it to them when I first had it in last week.
It's like a clunking/popping when transitioning from forwards to reverse and visa versa, only when manoeuvring slowly you can hear it, seems to be coming from under the front end, sounds like passenger side to me but could be wrong.
They think it's the pads moving about which it may well be, they ordered up new spring clips and pins anyway but just this last week since my first visit the brakes have started squealing like mad too so they need to look at that. This is on a fully revised setup that was all replaced last November under warranty.
Edited by Muzza80, 26 July 2015 - 02:59 PM.
Posted 16 July 2015 - 11:12 AM
Mine is more of a subtle creak type noise
Thought it might have been the front anti roll bar bushes but perhaps not as I've lubricated the rubber in them and it's still there.
Interestingly on hotter days the noise seems to stop so I'm convinced it's rubber related.
Posted 17 July 2015 - 01:54 PM
For anyone that's interested.
Car in with Norwich Audi today:
Traction issue - Found the car has a faulty Haldex pump, had one in already so fixing today (result)- £480 but covered under warranty.
I also had creaking in the front end, mainly during low speed turning at full lock - bent heat sheild, apparently corrected this and the noise has gone.
Quite pleased as dropped the car off at 12:30 today and will pick car up this afternoon. But will obviously have to check all in order when I get the car.
Norwich have always been really good so far - they sorted the brake squeal issue for me previously no fuss, although I found out that it wasn't done under warranty as it's considered an upgrade (go figure!), they did this under their 'Good Will' scheme. It was only that I bothered to ask that I found this out.
Posted 18 July 2015 - 11:45 AM
I got my car back yesterday too.
Faulty Haldex pump (as we knew) so that was replaced, woohoo I now have awd again.
My oily looking patch where the driveshaft enters the rear diff is, apparently, a "light misting" and does not warrant repair, it will be monitored at service intervals.
My low speed clunking from forward to reverse was due to an incorrectly torqued main driveshaft bolt, it was removed and re-torqued and this seems to have resolved it.
They could not replicate my brake squeal but have removed the pads, cleaned the insides of the calipers, the pads, re-greased and refitted everything, seems fine for now.
They also did my inspection service for £138 as no parts were required, they also ticked the "Haldex Fluid" box on the service list as replacing the pump the Haldex fluid was also changed meaning I won't get hit with that again in 10k miles.
Just had to pay for the service obviously as the car's in warranty some some time yet, cant complain really
Edited by Muzza80, 18 July 2015 - 11:46 AM.
