Did you pick up your RS then nobber?
Uprated Propshaft Bolts Round 2 - Group buy
#101
Posted 04 November 2014 - 01:48 PM
#102
Posted 04 November 2014 - 03:57 PM
#103
Posted 05 November 2014 - 09:20 PM
#104
Posted 05 November 2014 - 09:40 PM
Received thankyou ... 73nm torque on those bolts seams a lot anyone els think that. ?
The correct torque for wheel bolts is 120nm so imo 73 nm does not seem excessive.
#105
Posted 05 November 2014 - 10:21 PM
#106
Posted 05 November 2014 - 10:27 PM
Interested to see what markings they have.
Edited by Mr_Freeze, 05 November 2014 - 10:28 PM.
“Lightning" 2012 RS3, Ibis White (Sold). “Bumblebee” 2018 S1 Competition, Vegas Yellow (Sold). 2020 TTRS mk3 Sport Edition (Sold).
#107
Posted 05 November 2014 - 11:55 PM
Freeze - Haven't opened mine yet as not planning on fitting just yet.......
Only markings i can see on them (through the packaging) are stamped on the head itself - "ARP".
Guess they are made by ARP themselves:
#108
Posted 06 November 2014 - 12:43 AM
#109
Posted 06 November 2014 - 07:47 AM
excessive.
Yeah I suppose so it just sounded a lot I thi k there arp
Edited by jonniebrads, 06 November 2014 - 07:49 AM.
#110
Posted 06 November 2014 - 09:53 AM
When someone fits these bolts, can they take some close up pictures of the end of the propshaft and the Haldex input plate?
It looks like the problem we're seeing is not necessarily due to the specification of the bolts - all they should be doing is clamping the proshaft coupling to the Haldex unit, and any increase in torque *shouldn't* affect this.
I suspect there is a problem with the design of the proshaft coupling, or more speficially the metal sleeve inserts fitted in the rubber propshaft coupling itself. These should locate tightly into recesses machined into the Haldex plate, such that the bolts aren't taking any lateral load....
This is how it should work - the bolts should only be holding the propshaft tight to the Haldex unit and not actually providing any support for the lateral force. The green area should be taking all the force.
I suspect that either
a ) the recess in the Haldex plate isn't deep enough,
b ) the chamfer on the propshaft inserts is too much, or
c ) the fit between the two parts is too much, causing the bolts to take some of the load.
Option C sounds the most likely, and would fit with the problems we're seeing across standard and mapped cars - this stress would occur on all cars, but would be accelerated on cars running more torque. It would also fit with the fact that the Haldex unit part is unchanged, but the propshaft has been modified.
So while people are swapping these parts out, can you take some close-up snaps of the two parts, and if possible measure the dimensions of the propshaft sleeve and haldex recess with a micrometer, (or at least comment on how tight a fit this is - it should be difficult to pull the propshaft from the Haldex unit. If it just falls off then I think we've found our problem).
#111
Posted 06 November 2014 - 01:18 PM
#112
Posted 06 November 2014 - 01:56 PM
No worries Roy!
Everyone on the first GB has now paid in full and all bolts have been sent out as of this morning so thanks everyone.
#113
Posted 06 November 2014 - 01:59 PM
Just for reference (for the original Audi bolts), Elsawin quotes:
6 - Bolt
q
50 Nm + 90°
This is for the bolts that go through the coupling (Elsawin refers to this as Flexible coupling with vibration damper) and onto the propshaft.
#114
Posted 07 November 2014 - 06:57 PM
No worries Roy!
Cheers Nobber bolts arrived in work today now to find someone who knows what they are doing to fit them!
#115
Posted 09 November 2014 - 04:10 PM
#116
Posted 09 November 2014 - 05:00 PM
Apologies of someone has already mention this, but are the bolts not designed to be weak so they go before the propshaft does?
Maybe on a French car, but German engineers don't think that way. If they knew the design was marginal, they would have rectified it, (which is what they appear to have done with a new part superseding the original one).
It seems unlikely that a safety feature results in the propshaft smashing around next to the petrol tank.
#117
Posted 09 November 2014 - 07:23 PM
#118
Posted 21 November 2014 - 05:52 PM
#119
Posted 21 November 2014 - 06:37 PM
Don't ask me for a write up or how difficult they are to fit etc as I've no idea. I'll ask my tuner how he got on though!!
#120
Posted 21 November 2014 - 07:21 PM
Funny you should ask Roy, I had mine fitted today along with some other bits!!
It would be good for everyone to get a comparison and photo to the old bolts if possible to see if there is any evidence of wear stretching etc.
