Aftermarket seats
Posted 01 April 2022 - 06:26 AM
I have seen these Sparco SFX carbon seats which only weigh 12kg. The plan would be to have the rear trimmed to match and see what framework is like inside. If it’s heavy my welder mate will make something lighter before it’s put back together. The one thing I don’t want to lose is the the front seat heaters and wondered if you can buy the heater part with wiring to plug in?
Posted 01 April 2022 - 09:08 AM
Alternatively, find a breakers yard with the car that’s popped the airbags. Then gut them.
Posted 01 April 2022 - 10:21 AM
You can definitely buy the pads, so I think it would be a case of either buying new(see Tom at crew Audi) or just gut your current seats. Unless they’re super sports.
My seats are really good condition so I intend to sell them and wouldn't want to gut them. Good idea with the breakers yard.
Apart from the fact they are not in stock due to being a brand new seat, you cannot get a frame from Sparco for an RS3 8v and the same with OMP which are the same size. I might have to look at having some made unless I can find something online.
Posted 01 April 2022 - 12:46 PM
Edited by StephenG, 01 April 2022 - 12:46 PM.
Posted 03 April 2022 - 11:47 PM
Could check out AMX performance, will do plug and play recaros trimmed to match the RS3 interior, not as light as the sparco but still a good reclining option.
Very interesting site for sure and some great trimming.
I have spoke to a couple of dealers and found out the following on weights:
65 lbs - RS3 Super Sports seat
35 lbs - Recaro CS Sport seat
28 lbs - Sparco SPX carbon seat
These are figures taken off the scales. Sparco state the SPX was 12kg but it seems slightly heavier. CS weight is based on the material trim so full leather might be a bit higher but for the money are are not that heavy and great value.
They said the SPX is far better made but at 5 times the price of the CS it should be.
Either one the least you would save is 30 lbs a side which is a lot.
