VCDS Questions
17 replies to this topic
MB RS3
MB RS3
  • 156 posts
Is it possible to turn The autolock off on the car via VCDS so it never autolocks stationary or whilst driving?
Also how do you get the key fob to unlock all doors with one click rather than the standard 2? Is this possible also?
Cheers.
MB.
You don`t need vcds to do either of those. They are both alterable on the MMI screen.
Cheers.
MB.
MB.
Go into menu click Set- Scroll down to arrow @ bottom & click on- Scroll down again & click on arrow @ bottom.- click on Doors then you get the doors options.
All your current options are ticked....just untick or tick the options you require.
Edited by RS3Dell, 09 July 2020 - 07:29 PM.
MB RS3
MB RS3
  • 156 posts
Thanks for the replies.
Sorted the unlocking of doors in the menus. 👍
No mention of turning the autolock feature off in there though?
If yours is 8V then autolock is under the following on the MMI
Vehicle settings
Lock when driving
MB
It's below the door menu.on the 8P.
Edited by RS3Dell, 09 July 2020 - 08:43 PM.
MB RS3
MB RS3
  • 156 posts
MB
I looked below Dell and can only see the “parking aid” menu.
Cheers.
MB RS3
Hope this clarifies things.
Attached File  IMG_20200714_180023.jpg   26.65K   9 downloads
Attached File  IMG_20200714_180030.jpg   25.88K   10 downloads
Attached File  IMG_20200714_180036.jpg   26.21K   10 downloads
MB RS3
MB RS3
  • 156 posts
I don't appear to have the "Lock" option, strange...
  • 11,963 posts
May need coding with VCDS
Select STG 17 (instrument cluster)
STG coding -> function 07
Byte 0
Activate bit 4
Auto-Lock (lock automatically at speeds above 15 km / h)
Stupher10
Stupher10
  • 63 posts
Sorry to hijack this thread but I am a noob when it comes to VCDS too.
Is there anyway to have the boost gauge on the instrument cluster on the same screen where the digital speed is displayed? I put in a new head unit so nothing really displays where the radio station is normally so wondered is I could put the boost gauge there instead??
Thanks for any help
  • 11,963 posts
Thanks for any help
Not possible on the 8P platform unfortunately.
Stupher10
Stupher10
  • 63 posts
Ahhh no worries thanks for the heads up
  • 11,963 posts
Aftermarket head units aren’t 100% compatible with the DIS, something to do with the Audi protocols in the dash.
I remember nearly purchasing a pioneer head unit for my previous 8P RS3 and the place that sold then warned me that certain functions wouldn’t show up in the DIS.
Stupher10
Stupher10
  • 63 posts
Yeah it’s not a massive issue just looks abit bare now cause only shows the outside temp at the top and nothing else but I will just get used to it
It is possible using a MFD board upgrade however our model hasn’t been done yet. An 8J posted this recently so it’s definitely in the making.
https://youtu.be/VVG9VfQT8uk
Just adjust your display to a different setting so you don’t have to see a blank area if it bothers you. You can add the convenience menu through vcds which opens up a couple more values to be seen on the display, also shows you your fuel range even when the low level is enabled.
Stupher10
Stupher10
  • 63 posts
Cheers I will have a play about 👍🏻
