225 vs 235 tyres
Posted 01 June 2020 - 02:20 PM
This question has probably been asked before but does anyone of here run 225 at the front instead of 235 on there 8J rotors?
Is it a NO NO or is there no real difference?
Reason I want to is to have that slight stretch look plus it gives me a bit more clearance on the front with my 11mm spacers on.
Posted 01 June 2020 - 02:58 PM
Hi guys,
Bobby.
Remember your major drive is through the front wheels so going 225 for the euro stretch look will compromise grip.
I'm running 235 on 8j with a 8mm spacer & a 20mm drop without any clearance issues.
Posted 01 June 2020 - 03:04 PM
Bobby.
That’s true as well.
I’m running 11mm they catch on the screw but I have taken the screw out, so far it’s been OK. But thought I’d see people’s opinions on 225s
Posted 01 June 2020 - 03:20 PM
I'm only running the 8mm spacer so the wheels clear the 8pot brakes.
Can't you rise the car a bit instead of fitting 225s ?
Posted 01 June 2020 - 05:37 PM
I bought the optional wider 8.5J front rims and 255’s.
fills out the arch without a spacer.
Posted 01 June 2020 - 05:56 PM
8mm spacer running 8j 235s works out the same as running 255s & cheaper all the way round.
Br1ckt0p problem is his 235s on a 11mm spacer is catching.
Sign In
Create Account
Back to top
