034Motorsport vs H&R - Which One?
27 replies to this topic
MB RS3
MB RS3
  • 156 posts
Which Rear ARB..
https://www.awesomeg...-25mm-ttrs-rs3/
https://www.akstunin...udi-rs3-8p.html
Is the 034 worth over £100 more?
How many of you have either? I know the 034 is pretty popular.
Thanks.
Which Rear ARB..
Thanks.
034 was the only rear arb about when i fitted mine but for that money i would have used the H&R instead.
Pil5burydoughboy
Pil5burydoughboy
  • 473 posts
  • LocationAberdeen
Which Rear ARB..
Thanks.
I have the 034 arb due to the excellent reviews it got but pretty sure the H&R one will be much the same.
Evil Diesel
Evil Diesel
  • 1,610 posts
I went for the H&R - the 034 is slightly more adjustable but, in reality, who is going to bother once it is fitted.
The other upside I noticed was that it solved the pan roof creaking - shows how much body flex there is with the stock bar.
MB RS3
MB RS3
  • 156 posts
Thanks for the replies.
Do you all have it set on the stiffest setting?
Cheers.
Cheers.
I've been running the stiffest setting from day one......The RS rotates nicely on turning with zero understeer even in the wet.
Evil Diesel
Evil Diesel
  • 1,610 posts
I think oversteer was the issue on the 25th Nov Dell.  Quality spin in the chickane (which was as slippy as a fish).  Between you and me I suspect the instructor is looking for alternative jobs!
  • 1,083 posts
034 here, mainly because at the time I could find anywhere that sold the H&R rear only.
It was part of a set and I didn’t want or need the front arb.
034 here on its stiffest from the start,  I thought I had an issue soon after fitting, but turned out to be a 20mm washed gravel stone off my driveway rattling about in the hollow wishbone, which was promptly removed.
front end turn in improved remarkably, I also then added the optional 8.5j 255 staggered set up.
Turns in like it’s on Velcro.
Only on the 1st lap due to cold tyres.....once warmed up not a problem Tony.
Delll.
MB RS3
MB RS3
  • 156 posts
Did you find a big improvement with it fitted over OEM mate?
MB RS3
MB RS3
  • 156 posts
With H&R now selling rear only now - what would you of opted for?
Sounds really good.. I think every review I have seen of a aftermarket rear ARB especially on the 8P is always so positive.
  • 1,083 posts
Hmm having just being reminded of the H&R purply blue colour , which shouts  modification to Audi, ( I was still in 5 yr warranty then)
I probably have still gone with 034 black, despite its logos and stickers, which soon weather off..
then only the brackets / grease points give it away.
Here's a thought under what circumstance would the aftermarket ARB affect a warranty claim....none really tbh.
I got the H&R bar then powder coated it black. Audi proof.
  • 1,083 posts
true, but I couldn’t be bothered  with the hassle or argument if there was an issue.
i had top mounts on the front replaced under warranty,  I’m sure if it had been the rears , they would have tried to wriggle out of it, due to non standard part fitted as part of the suspension.
Well there's the rub of extended warranty 🤔
Evil Diesel
Evil Diesel
  • 1,610 posts
My H&R bar is black.  Fitted in October so maybe there has been a change.
Anyway, given the general competence of the Audi Techs I doubt they would notice either way.
Evil Diesel
Evil Diesel
  • 1,610 posts
Stops a lot of body flex - had the pan roof creaking a lot before fitting and silent after.  Worth it for that alone!  No adverse effect on ride quality (for those in the fornt anyways - had the Outlaws over from Sweden in early Jan and they were looking a bit green after a 40 minute blast).
On the track it is a lot more pointy although the downside is you are at risk of both understeer and oversteer depending on the conditions / corner - you have to balance it better.
Pil5burydoughboy
Pil5burydoughboy
  • 473 posts
  • LocationAberdeen
Surely nobody has warranty now on a 8/9 year old car.
It was mentioned by Paul as he has/had an extended 5 year warranty on his RS.
I don't worry about things like that tbh.
