What tyre pressures are people running, mine seems to be a bit crashy on the front, thinking maybe a little low
Tyre Pressures
Posted 02 February 2018 - 07:42 PM
18 Plate St2 TTRS, Roadster, 20" OZ Indy HLTs, Forge IC and Hard pipes, Audi Carbon Mirrors, Automotive Passion spoiler, Side skirts and front air vents. Scorpion full system all tuned by MRC
Posted 02 February 2018 - 08:59 PM
Posted 02 February 2018 - 09:48 PM
Posted 02 February 2018 - 10:25 PM
robokn.
Try as a starting point running the pressures as on the sticker in the drivers door shut.
I run 235/35-19 on all 4 corners at 45psi all round & my tyres wear evenly on my 8P.
Edited by RS3Dell, 02 February 2018 - 10:27 PM.
Posted 03 February 2018 - 08:25 AM
They’ll vary any way as the tyres heat up / cool down constantly.
Posted 03 February 2018 - 09:06 AM
And remember to check regularly temperature and pressure are relative, laws of physics and all that.
I find that after I check and add more pressure it sharpens things up quite noticeably
One of the cheaper (free!) and easy measures to take that improves performance
OMR
Posted 03 February 2018 - 10:05 AM
Yup door sticker values and pumped up to the max Regardless of load, how many people you normally cart about.
OMR
At the advanced driving day I attended the Audi Lead Instructor said to run the RS3 on the road at the "maximum" (as in the pressure for a fully loaded car) as it feels more alert and the chassis is set up for that. Didn't matter if staggered or square setup he said.
I used to find the front would struggle for grip when cold and would "slap" on expansion joints badly at the higher pressure though. Swapped to MPS4S tyres and its almost perfect now and always precise and forgiving on broken tarmac at full pressure.
Posted 03 February 2018 - 10:16 AM
The sticker is there to guide us so in my opinion that’s what I use.
As the above post, the car has been setup / fine tuned on these pressures.
Why people think they know better when Audi have given the precise info is beyond me.
Posted 03 February 2018 - 10:52 AM
Posted 03 February 2018 - 08:01 PM
mfurse.
I'm running MPS4s also In the wet,dry,hot or cold i just can't fault them with the higher tyre pressures.
I did a 20mins track session at Castle Combs RSFest last year & afterwards the MPS4s looked like new mate.
Edited by RS3Dell, 03 February 2018 - 08:02 PM.
Posted 11 February 2018 - 03:24 AM
Anyway, I had a tpms light saying front right was flat (it wasn’t ) but gave them all some air and it absolutely transformed the handling. They were all down about 6-7psi from suggested after only a few months of owenership. Now back to 39.5 front and 36.5 rear and feels great.
If you track your car drop it down a good margin as you’ll be amazed how quickly pressures build up. Although if you track your car this is probably telling you what you already know.
Posted 12 February 2018 - 10:27 AM
Recently it's been hovering around 3 degs, and mine needed a puff when checked.
Your right about track use, needs monitoring and adjustment,
it's findimental and a lot of people seem to ignore it, and makes such a difference....
OMR (tyre pressure OCD)
Posted 12 February 2018 - 04:30 PM
Posted 20 February 2018 - 08:10 PM
Checked mine today as the Tyre Pressure Indicator came on on Sunday. Now as the car is only 2 months old I thought the pressures would be somewhere near the recommended as shown on the sticker...
WRONG..
33 psi all round!
So I've gone for the 39 front and 35 rear for now....
Posted 20 February 2018 - 09:23 PM
Posted 26 February 2018 - 03:21 PM
Currently running 44 all round seems to work a treat
Posted 02 April 2018 - 05:33 PM
The pressures seem to be all over the place from the factory. My last one (delivered in December) had 35psi front and 37.5 rear. The new one has 40.5 psi all round.
They both seemed pretty solid tbf.
Posted 02 April 2018 - 08:58 PM
They should be checked & inflated to Audi spec on the PDI at the dealers before delivery to the customer.
Edited by RS3Dell, 02 April 2018 - 09:01 PM.
Posted 02 April 2018 - 10:02 PM
Posted 07 April 2018 - 08:40 AM
Does anyone have a picture of the door sticker that shows the OEM staggered setup: 255/30 front and 235/35 rear???
In Audi's quest to make life easy, I checked my door sticker but given I'd gone for the standard setup this is all that was one them...
I then thought RTFM!!! And I did, and there are no values given in the book - doh!
Given I've moved to the new setup I'd like to know what Audi recommends. I'm currently running 39 front and 35 rear on the MPS4S tyres...
Thanks in advance!
