255/30/19 or 235/35/19
Posted 26 July 2016 - 08:05 AM
Posted 26 July 2016 - 08:10 AM
Remember if you currently run 255 front and 235 rear and swap to 235 all round or you switch to 255/235 the ECS system's adaption should be changed.What rides better on the front, I have a spare set of 235/35/19s, and I hate the pirrellis that the car comes with but I do like the wider front tire, anyone experienced any differences and what would be the best option? To run the same all round or run the staggered fitment and keep the pirrellis
I have not tried 235 all round so can't comment on that aspect, I run MPSS 255/235 and they work well for me
Edited by Arcam, 26 July 2016 - 08:14 AM.
Posted 26 July 2016 - 08:25 AM
Posted 26 July 2016 - 08:30 AM
No but the CS are on my list for next time, they are 30% more expensive than my current MPSS not sure they are 30% better however 😀Yeah a think the tyres size works well, it's just the pirrellis I don't like, I had them on my previous RS3 n hated them, but just seems to waste these ones when they haven't been used, have u tried the cupsports before
Posted 26 July 2016 - 09:23 AM
Haha true that's a good way to look at it a suppose, I want to bin the pirrellis just don't know what to get, I have a full set of continentals could just buy the wider fronts and they would be better a suppose
Posted 28 July 2016 - 12:06 PM
How do you change the ECS system? I am currently on 235/35 all round...
Posted 28 July 2016 - 12:18 PM
It will be a setting in VCDS assuming it is not one that Audi have locked out, I know the dealers can do it for sure.
Posted 28 July 2016 - 03:43 PM
Cheers, excuse my ignorance but whats it all about and what does it do?
Posted 28 July 2016 - 03:50 PM
If you are referring to the ECS system then it is the computer that looks after the stability control and a large portion of the info it uses to calculate when it is all going **** up (loosing traction/skidding etc) is the rpm of each wheel.
Now with different sized tyres front and rear and the aspect ratios not fully matched there is a speed difference when all is going well, so the ECS computer needs to know what speed differential is when all is OK so it knows when it isn't ... does that make sense? Hence the adaption needs to be changed when swapping 235 all round for the 255/235 combo.
Edited by Arcam, 28 July 2016 - 03:51 PM.
Posted 28 July 2016 - 04:23 PM
Arcam
Are you sure about this? I`ve had 225/235 235/235 235/255 .All worked well with no warning lights.
Posted 28 July 2016 - 04:42 PM
Had 255's on the mark 1 with no issues
The stability control will be monitoring the ABS rings to see what's doing what.
Posted 28 July 2016 - 04:59 PM
All I will say is the 255/235 combo has more bite / grip at the front and works well as opposed to my 8.5J 235/35 all round
Posted 28 July 2016 - 05:57 PM
Absolutly, if the rolling radius matches then all OK. If not the ESC needs to "know".Arcam
Edited by Arcam, 28 July 2016 - 05:58 PM.
Posted 28 July 2016 - 06:10 PM
I understand that but the rolling radius of 225 235 255 are all different.
Posted 28 July 2016 - 06:12 PM
Not necessarily, it depends on the aspect ratio to tyre width.I understand that but the rolling radius of 225 235 255 are all different.
Posted 28 July 2016 - 06:13 PM
Posted 28 July 2016 - 06:19 PM
I have seen it at my dealer when they were checking for the ESC cutting in, they told me to the 2 settings and I did say the settings nay he locked down.where is this mysterious Adaptation ?
Edited by Arcam, 28 July 2016 - 06:20 PM.
Posted 28 July 2016 - 06:30 PM
I'm pretty sure the car will measure the rolling radius on each Axle set /four corners anyway and adjust to suit.
The tyre circumference difference from 235 to 255 is 36.1mm
I'm the same as Neil have swapped from 235 to 255 / 255 to 235 (winters) both cars and never have any issues with warning lights / VCDS errors at all................
Posted 28 July 2016 - 06:34 PM
Just ask a MT at a dealers.I'm pretty sure the car will measure the rolling radius on each Axle set /four corners anyway and adjust to suit.
Posted 28 July 2016 - 06:37 PM
I wouldn't trust an Audi Master Tech as far as i could throw one...............
