Front Brake discs
112 replies to this topic
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
So whos running what? Any upgrades other than Tarrox?
My front discs have given up after 50k miles (3k of me being hard on them is enough for them to quit) i just put on yellow stuff pads also.
The brakes on the RS3 are in my opinion quite bad lol, Coming from the RS4 which was a big heavy bus to stop i just feel the brakes are pretty weak,
stage 2 8p 445BHP 518lb ft
Having run EBC Red and Yellow, Red's are better on OEM discs and then swap the OEM to 8pot calipers, you'll have far better brakes.
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
do EBC stock red stuff for the front i was struggling to find them,
  • 1,083 posts
DP31210C for the fronts
DP31518C for the rears.
If you want to retain the front brake pad wear sensor, you will need to buy
DP32070C TTRS Redstuff Pads from Summit Racing in the US.
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
superb thanks mate
50K miles on one set of discs? Mine were shot to shite at 22K at most!
Get the Reds, 13K so far on reds and no complaints. Discs have minimal wear and braking is sooooo much improved.
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
i dunno if its had a set before i got it i got it with 47k on it lol  :ph34r:  :ph34r:  must have had a set before i would imagine but 22k isnt a lot you sond worse than me on them :D  :D  :D
No I bought the car with 19K on it but it was the shite Audi pads fitted from new that ate the discs. Lots of threads on here about it but over time the Audi/ Pagid pads wear grooves into the discs due to the metal pins they use to hold the material on to the backing plate.
I found this out when trying to brake from 140 MPH... Severe brown trouser moment.
Happily not to re-occur with the Reds.  :D
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
:11:  :11:  :11:  :frantic:  :frantic:  :frantic:  brilliant, ive just ordered new discs might opt for the red stuffs,, grudge it because i have had the yellow stuffs on for about 1k of abuse lol
45bvtc
45bvtc
  • 749 posts
  • LocationStaffordshire
Go Redstuff front and rear for a road-going no worries brake pad; 2-years on and Redstuff remains for me a very brake-disc friendly brake-pad.
My OEM items are still on my garage shelf - with a set of horrific OEM front pads Duke3D kindly sent me - and have zero chance of going anywhere near my calipers ever again   :ph34r:
FlyingScotsmanSK
FlyingScotsmanSK
  • 135 posts
  • LocationFalkirk
HI Paul,
Is there no one in the UK that stocks the DP32070C TTRS pads ?
I can see them on Summit Racing USA page.
RS3 8P MRC Stage 3 map/DSG Stage 2 map
Forged Engine/Schrik Cams/ TTE500/Full Milly/034 Air Intake with cold air feed/Forge Intercooler/Aquamist water/meth kit.
HI Paul,
They don't sell them here in the uk....
When I rang EBC they wouldn't even look into available sets for the uk market...
I was told in no uncertain terms RedStuff pads were not available for the 8p RS3, the only one they offered was the Yellowstuff pads.
When I mentioned that the Evo pad fitted as its the same caliper they again said no to RedStuff pads.
When I asked why...... They said the RedStuff was only suitable for the American market as it was more suited to their style of roads.
I had Yellowstuff on less than 2 days before they started falling apart, when I emailed / rang EBC they said its 'normal' Sir.
Then gave up with EBC as a whole.
Or go 8pot caliper and EBC make Redstuff pads for them....
FlyingScotsmanSK
FlyingScotsmanSK
  • 135 posts
  • LocationFalkirk
I have never tried yellow stuff pads before but had redstuff ones on my scoobys and never had any issues with them.
Will order a set from the USA, and see how long they take to arrive.
Cheers guys!!
  • 1,083 posts
Hi, the only place I found them was in the US.
Ironically they are made in the UK shipped to the US and I paid to ship them back.
I chose these over the other set in my post above because I prefer to retain the Audi brake wear sensor.
Cost was in the region of £125 shipped . Took a couple of weeks , Summit keep you updated with progress.
Edited by Paul, 11 March 2016 - 12:08 PM.
FlyingScotsmanSK
FlyingScotsmanSK
  • 135 posts
  • LocationFalkirk
Thanks Paul, I would prefer to keep wear sensor as well so will go with Summit.
Did you just order rear reds from  the UK?
Did you need to pay import tax on the US ones?
  • 1,083 posts
I ordered the rear reds with my MTEC drilled rear discs as there was an offer on.
When you order with Summit there is a postal option that includes all the taxes/ duty etc ... So I paid it all at the cart.
Don't worry too much about the back order status, they arrived sooner than anticipated.
$183.40 is £128.21 at today's rates xe.com
Attached File  image.png   43.62K   28 downloads
Edited by Paul, 11 March 2016 - 12:05 PM.
  • 1,083 posts
Audi pads are circa £250 iirc.
And they are shite. Reds massively superior. No squealing either.
stevo_123uk
stevo_123uk
  • 182 posts
  • LocationGlasgow
the yellows are decent but just no doing it for me, ordered new discs and will stretch some more out the yellow stuffs before i change them.
