Fitting cat bypass pipes
Posted 19 April 2015 - 02:29 PM
I hate having to pay garages to do easy jobs but the problem is getting enough access under the car using jacks or wheel ramps alone.
Posted 19 April 2015 - 04:09 PM
About 45 mins all in.
Excellent mod and sounds gorgeous
Posted 19 April 2015 - 07:56 PM
Next question to everyone.
Scorpion or Milltek?
I know technically they are just metal pipes but does anyone know off the top of their heads differences between the two? Build quality, thickness of the metal tubing, weight etc?
Posted 19 April 2015 - 07:58 PM
Are these bypass pipes MoT legal, or does it depend on luck of the draw with the tester on the day?
Posted 19 April 2015 - 09:07 PM
The vehicle will pass its emission test with the secondary cats removed (as it sill has the main primary cat) but the tester should be carrying out a "presence" check as part of his examination, so if he (or she) knows that the vehicle in question should have the secondary cats fitted as standard then its a fail once removed.
Most testers I know will pass if it passes the emission test.
Mark
Posted 19 April 2015 - 09:40 PM
Thanks Marshy, sounds like it's worth me giving it a go. Did you jack up both the front and rear on the offside of the car or just use the front jacking point?
Scorpion are just as good if not better than Miltek but don't cost anywhere near as much.
I have Scorpion and I inspected them thoroughly before fitting.
They are definitely quality items. The rest of the system is of the same quality.
“Lightning" 2012 RS3, Ibis White (Sold). “Bumblebee” 2018 S1 Competition, Vegas Yellow (Sold). 2020 TTRS mk3 Sport Edition (Sold).
Posted 19 April 2015 - 09:42 PM
Mark
It's always helpful having a friendly knowledgable MOT tester who's happy to do the MOT for you
Mark would suggest one if you ask him, if your in the South.
Posted 19 April 2015 - 09:54 PM
Thanks for that chaps. Do you have a Scorpion exhaust Mr Freeze, or just the bypass pipes?
Posted 19 April 2015 - 10:21 PM
Thanks Mr Freeze that's all I wanted to know. £30 cheaper to boot.
Posted 20 April 2015 - 09:28 AM
Differences from what I gather are very little apart from the scorpion cost £150 and doesn't have the little tags on saying not for road use like the Milltek does.
Posted 20 April 2015 - 10:58 AM
Posted 20 April 2015 - 11:04 AM
Posted 20 April 2015 - 05:57 PM
And they come with a Sticker.😀
Edited by DAYTONA-500, 20 April 2015 - 05:57 PM.
Posted 20 April 2015 - 08:51 PM
I jacked the front up which lifted the back anyway, so I lifted the rear to and out an axle stand in.
Thanks again. I'm sold on the Scorpion pipes. If my local MOT centre fails it I will just re-fit the Cat pipes and get it through on the re-test.
Posted 20 April 2015 - 09:13 PM
Yes, started with fitting the bypass pipes, then went on to get the cat back non res system.Thanks for that chaps. Do you have a Scorpion exhaust Mr Freeze, or just the bypass pipes?
Edited by Mr_Freeze, 20 April 2015 - 09:18 PM.
Posted 20 April 2015 - 09:15 PM
Posted 21 April 2015 - 06:40 AM
I'm debating whether to go for res or non res - how do you find the non res on motorways, any drone (excluding that which may come from any passengers, of course ) ?
Posted 21 April 2015 - 05:07 PM
At any speed, if you're accellerating gradually, it seems like 3k rpm is the spot where you get the worst drone.
Equate that to motorway driving and you have to be in excess of 70 to get there.
I won't lie, at times it can be a touch uncomfortable, but mine is a fun car, and as such when I drive it I'm having fun and listening to Lightning growl, can't help but put a smile on your face.
I don't know where you are but if you're close enough to come listen, I'll gladly take you for a spin.
Posted 21 April 2015 - 09:12 PM
As Neil has said above, there can be a "drone" at certain RPM / road speed combinations, Mine is fitted with a full Milltek system and being critical it can drone a little at 100 Mph, but as he also states the "fun" & "growl" far out weighs any negatives
Mark
Posted 22 April 2015 - 10:38 AM
Mark
Is the full system res or non res?
