Okies folks, I'm wondering if anyone has any experience of this and/or might be able to shed any light:
Twice now I have been driving along and a really loud screaming/screeching noise has started coming from the car. The best way I can describe it is like when you get a knackered waterpump bearing, or a slipping fanbelt.
The first time it happened (around a week or so ago), I brought the car to a halt and pretty much as I stopped, the noise stopped. I set off again, and the noise was still there, so I stopped, moved the gear selector first into "N" and then into "R", and I reversed a couple of feet. When I went back into D and set off again, the noise was gone and never re-occurred ........ until today.
Driving along again and the noise started, so once again I brought the car to a halt - braking made no difference to the noise, nor did revving the engine - no change in pitch or anything.
Once again, I went to set off, and the noise was still there. I again reversed a little bit, and then set off again, and the noise was gone and never returned for the remainder of my journey (around 70 Miles).
The common factor on both occasions has been that it has been raining, and there has been quite a bit of standing water. This initially made me think it was a belt getting wet and slipping, but the fact the noise changes not with engine RPM, but with vehicle speed, suggests that isn't the case.
My next thought was brake noise as I have heard similar noises when dust guards (backplates) have been catching, but I can see no reason for this to happen only in the rain, nor was there any change in the noise when actually using the brakes.
Any ideas?
Edited by martynrich67, 19 July 2014 - 09:55 PM.
Sign In
Create Account
Back to top
View Garage
