Having seen T-800's avatar I am sure he will be a fountain of knowledge on this subject.
Has anyone fitted a DS1 and do they think it is worth doing?
I understand you can have more switching maps, but what I am not sure is on the use of e85 and octane boosters. As I understand it there is no point adding octane booster that has a lower calorific value than 98/99 pump fuel so needs the timing etc. altered to suit, preferably with a different map for each type. Does this allow you to run on the same map and just add varying fuel without changing maps, or am I being a bit optimistic?
https://www.dynospec...ttrs-med17-1-62
