Old(ish) aged Audi... Things to check?
12 replies to this topic
Seb_RS3
Seb_RS3
  • 389 posts
  • LocationHeysham
so my 8P is approaching 65,000 miles and is still proving to be a fun and reliable daily driver. I was wondering though if there was anything that's not covered under the usual kind of service inspections that I should be looking into getting checked / replaced to ensure that the car keeps going strong?
Cheers for any suggestions.  :)
  • 2,701 posts
Decoke, injector replacement and loctite swirl flap screws in.
Edited by JayRS3, 08 September 2020 - 07:17 PM.
Seb_RS3
Seb_RS3
  • 389 posts
  • LocationHeysham
I thought decoke would be one of them.
Are OEM injectors the way to go for replacement?
And what are swirl flap screws? Not familiar with those...
  • 4,492 posts
The injectors originally fitted can fail so fit the OEM superseded one's,also the swirl flap screws in the inlet manifold can come loose & get digested by the engine with catastrophic results 😳
Seb_RS3
Seb_RS3
  • 389 posts
  • LocationHeysham
Well that doesn't sound good. I'll definitely be getting that done!  :o  :lol:
  • 2,701 posts
What dell said. It makes sense to do it the same time as the decoke and injector replacements as everything is off anyway so saves on labour/ new gaskets etc. Will be an expensive visit for sure but piece of mind
Seb_RS3
Seb_RS3
  • 389 posts
  • LocationHeysham
No doubt. I'll make enquiries about the cost when I get the service done this time. But as I'm going to be keeping the car for a while longer and using it every day I don't want it to die on me any time soon. Haha.
RS3Rob
RS3Rob
  • 41 posts
Do we have an exploded picture of these swirl flap screws? Also a revised part number for the newer injectors?  :up_it:
  • 2,701 posts
3e598b2c756982e7503c235c82a84f29.pngab977bc17071e50d71c282ae6b81172b.jpgcc989cf1fd965c3c4de789a398a4f6cf.jpghttps://uploads.tapa...20cc94af4.plist
See attached images. New core plugs can be purchased 12/13mm I can’t rmemeber top of my head. You can see by the diagram where their located though. Also see part number for injectors.
  • 4,492 posts
Rob.
The injectors I fitted last year may have been superseded so Audi will only supply the most up to date one's.Here's the swirl flap screws.Attached File  20190601_123223.jpg   49.96K   9 downloadsDell.
Edited by RS3Dell, 09 September 2020 - 11:52 AM.
  • 4,492 posts
Rob.
I didn't replace the screws I just remove & refitted using a strong Loctie supplied by Jay,the core plugs are 12mm which I purchased off eBay via a link from Jay.
Some screws came undone easily others were right pigs due to the inconsistent amount of thread lock.
Edited by RS3Dell, 09 September 2020 - 12:41 PM.
RS3Rob
RS3Rob
  • 41 posts
Much appreciated for that boys as usual  :up_it: .
So just to confirm and excuse my simplistic mind, you need to remove the 'core plugs' to get to the screws/bolts? Initially i was thinking the screws we're the core plugs but actually its the screws behind the plugs/bung?
I'll put this on my list of many jobs to do, Cheers!
  • 2,701 posts
Correct, the plugs are essential a cover with the screws directly below. Obviously the core plugs serve a purpose for pressure but yes. Just punch them out and punch them in (with the lower intake on the table) not on the car.
