Hi,
Can anybody point me in the right direction of a part number for the standard locking wheel bolts? I've had break one of mine at weekend. I've contacted a few ebay sellers because to replace but they've all mentioned slightly different part numbers. Attached is a response from a seller that mention a 2 part bolt. Will a standard 1 part fit or does it specifically need the part? I can only assume it means the spinning collar on them.
Thanks
Screenshot_20200415-175616_eBay.jpg 108.79K
8 downloads
Locking Bolts
Started By
Jamesybaz
, Apr 15 2020 04:54 PM
2 replies to this topic
Posted 15 April 2020 - 04:54 PM
Posted 15 April 2020 - 05:03 PM
Hi,
James.
Main agents or TPS as they can supply a replacement bolt to the same code as your original.
Btw there's a No's or letters stamped on the locking bolt key which there need to know when ordering.
Edited by RS3Dell, 15 April 2020 - 05:08 PM.
Posted 15 April 2020 - 05:06 PM
Mike at Coverdale parts (formerly at RPS) sorted me out with replacement set £40 for a full set and key. You don’t get to choose which key bolt combination you get though.
There are a number of different versions obviously as they wouldn’t be that secure if we all had the same (not that they are that secure anyway).
FYI the one bolt price almost the same as a full set price
You can find them on Facebook.
Edit: if you opt for 1 bolt rather than a whole new set they can match the bolt to your key.
Key part numbers if that’s helpful.
Edited by OllieC, 15 April 2020 - 05:08 PM.
