Dash cam 2019
Posted 30 November 2019 - 03:23 PM
Been using an OEM+ 1080p front camera for a few months but in order to attach a rear I need to change the front camera to be able to run another feed.
So with that being said I’ve used this opportunity to change and go with an aftermarket alternative.
Currently looking at the Blackvue 4K DS900S 2CH as I don’t really want to compromise on quality when it could be used for such an important case. More of an investment that can be taken with me.
Is it worth purchasing the power magic pro box too for when it’s parked?
Also there seems to be 16GB & 32GB versions with about a £100 price difference. Can I not just change memory cards or is this the internal memory?
Any suggestions feedback welcome please.
Posted 30 November 2019 - 04:06 PM
Good afternoon chaps
I’ve purchased it along with the 24hr parking battery pack
Posted 30 November 2019 - 05:07 PM
Word of advise, I have also been tempted to go with a cheap high memory sd card but for some reason certain types can cause issues with the camera. They are pricey but the oem blackvue ones seem to be fine! If you read up on it there are people who have had no issues with non blackvue cards, but options are limited and of course there’s a risk it might not work with your unit.... hope this helps
Posted 30 November 2019 - 05:08 PM
Posted 30 November 2019 - 06:08 PM
Let me know mate. Can always cancel the Blackvue battery optionForgot to mention, there are also cheaper battery packs that work fine (I have one of them) so if you need any details just let me know
Also advise/recommendations on compatible memory cards would be ideal as well as I purchased the 16GB version camera as it was £100 cheaper and I have every intention of buying a 64 or 128 GB card
Edited by JayRS3, 30 November 2019 - 06:09 PM.
Posted 30 November 2019 - 06:15 PM
Posted 30 November 2019 - 06:36 PM
I’m running the Thinkware F800 pro on both cars.
Superb fit and forget setup.
I read about this one and it something like it records in 1 minute segments then misses a few seconds before recording the next segment? I’m guessing this could cause an issue if it so happened an incident occurred during the transition of segments. Odds are against it but you never know.
Posted 30 November 2019 - 06:47 PM
Hmmm can’t say I’ve ever noticed that to be honest Jay.I read about this one and it something like it records in 1 minute segments then misses a few seconds before recording the next segment? I’m guessing this could cause an issue if it so happened an incident occurred during the transition of segments. Odds are against it but you never know.
All I know is it performs faultlessly and with a 128GB card.
Posted 30 November 2019 - 07:23 PM
I run a DR650S Blackvue and have a massive assortment of 32, 64 and 128GB micro SD cards that work for a bit and then get random reboots of the camera which results in lost footage. I have not found an aftermarket card that works for me yet so have resorted to the stock 16GB card. I have tried looking at the card info to try and work out the manufacturer as I am certain BlackVue put a premium on their cards but no joy. If you find one that works please do let me know
Posted 30 November 2019 - 07:37 PM
I'm running a Blackvue 750 front and rear and use the power magic pro.
Cutoff is set to 12v on the power magic pro and on my car it lasts roughly 5 days in parking mode before switching off.
I tried a few cards and always an issue, but after looking on the Blackvue forum use the following and has worked for the last 9 months with no issue.
Link to card:
https://www.morecomp...BBEU633A>>Lexar
Hope it helps.
Vik
Posted 30 November 2019 - 08:35 PM
Thank you - purchasedHi,
Link to card:
Hope it helps.
Vik
Edited by JayRS3, 30 November 2019 - 09:30 PM.
Posted 30 November 2019 - 08:41 PM
Jay.
Remember the recording is done on a loop so you don't really need a big memory card mate.
Posted 30 November 2019 - 09:01 PM
Jay.
4K content takes up quite a chunk of memory plus for the battery pack it allows multiple days storage so worth getting a larger card for a lot more storage just in case
Posted 30 November 2019 - 09:19 PM
The thinkware has a decent app also.4K content takes up quite a chunk of memory plus for the battery pack it allows multiple days storage so worth getting a larger card for a lot more storage just in case
You can view all footage and download to your phone.
Posted 30 November 2019 - 09:36 PM
Posted 30 November 2019 - 10:01 PM
Posted 30 November 2019 - 10:12 PM
Tbh do you really need 4k ?
Posted 30 November 2019 - 10:31 PM
I would say it is.. I've also got a 4k CCTV camera pointed to where I park (Dahua 6MP with Sony sensor), and find to get the detail of something on the edges it helps when zooming in.
I think for dashcam it will be the same...say you see a numpty throwing things off a bridge onto the road and catch it on the dashcam...you should be able to zoom in to the face for clarity.
Posted 30 November 2019 - 10:37 PM
Way I see it, if your going to the expense of buying a dash cam then I want the best quality as ultimately it could be the difference between catching minor details or not. Anyway it’s an investment and can come along with me with any vehicle.Tbh do you really need 4k ?
Posted 30 November 2019 - 11:15 PM
The battery pack I’m using is a cellink B and I’ll see if I can dig out info on the sd card. As said previously not all will work but there are a few that will. Hope this helps
