Decided after some searching online to purchase these from ECS.
Edited by T-800, 15 November 2019 - 07:06 PM.
Have you been having misfires / rough idle then Sean?
Itās a good job you aināt swapping them then isnāt it............Coil pack swap is a gimmick!!
Same as the spark plugs! I am on stock plugs and coils running 2bar of boost for nearly 12 months now, no issues at all.
Lets see how you get on mate. Isn't it a bit of a bastard to get to cylinders 3 - 5?
Not really EDLets see how you get on mate. Isn't it a bit of a bastard to get to cylinders 3 - 5?
Always a man of mystery Sean.
If you are looking for a new home for the second hand, old, used, tatty and very cheap JB4 bear me in mind.
Eh???FYI if you want them to work correctly the ECU needs coding as firing signal time is different to stock! But as you say lucky I'm not fitting them.
Eh???
They are a oem coil pack with a red top.
What's your point?
Red top is from NA engines there signal is different by milliseconds, they will work fine still but will make zero performance enhancements and also will actually burn out quicker due to not calibration with ECU....
Edited by T-800, 18 November 2019 - 06:26 PM.
How are the new coil packs ?? Any difference ?Well they arrived today after being ordered on Friday (very speedy delivery)
Just fitted them.
Will report back if they are worse/same/better etc.
No ECU calibrations required as they are same part number just revision āLā I verified this with ECS and someone else today.
Looks so good I may leave the cover off
Yes they are red
No noticeable difference.How are the new coil packs ?? Any difference ?
If that engine was female you'd be turned to stone if you looked at itWell they arrived today after being ordered on Friday (very speedy delivery)
Just fitted them.
