Someone was kind enough to share their VIN with me, so here's what I found out during a quick look into both engines. So mainly the part numbers are the same, aside from the last revision numbers, which I honestly have no idea what they mean. So for example:
DAZA/DNWA:
- Engine Block: 07K 100 032 J / 07K 100 032 K
- Cylinder Head: 07K 103 064 C / 07K 103 064 D
- Pistons: 07K 107 065 AB / 07K 107 065 AC
- Outlet camshaft: 07K 109 022 E / 07K 109 022 F
There are several more differences (waaay too much to list, but mainly the same). Even intercooler has a different revision number. But inlet camshaft is the same and turbo is the same.
The bigger differences seem to be with fuel pump and intake manifold, which are even separated in the catalog. The part numbers for main part:
- Fuel pump: 07K 127 025 D / 07K 127 025 E
- Intake manifold: 07K 133 201 AT / 07K 133 201 BC
Some other interesting facts:
- Backboxes seem to be largely the same (again only revision is different, but can't compare directly, as the DAZA VIN I had has standard, not sport exhaust).
- DNWA has no midpipes like DAZA, but rather downpipe and midpipes seem to be one part.
- Exhaust manifold is the same.
- ECU is the same, except for revision again.
- Transmission has completely different code.
Again, note that I am no expert, just wrote what I noticed. If you're looking for one specific difference, please let me know and I will look it up. I have no idea how to check compression ratio, or what those revision changes mean. I know in some cases it can mean completely different internals, when on others it's just newer production date, so if anyone else can shed some light, that would be awesome!
