Does anyone know the wiring ie ground / signal out / 5v power in on a G28 crank sensor. I`ve found from Elsawin power in is pin 1 but get conflicting answers on pin 2 and 3.
G28 pin out.
Posted 17 August 2019 - 06:30 PM
Posted 18 August 2019 - 09:07 AM
Posted 18 August 2019 - 03:49 PM
Sean
That`s what I found .It tells you which is ground but not the other two.
Posted 18 August 2019 - 03:56 PM
Sean
Signal wires ? Why you need to know ?
Posted 18 August 2019 - 04:09 PM
SeanSignal wires ? Why you need to know ?
It`s for a Motec ecu I`m fitting on a UR Quattro engine. I need to check the output of the CPS before it`s connected up.
Posted 18 August 2019 - 05:21 PM
SeanIt`s for a Motec ecu I`m fitting on a UR Quattro engine. I need to check the output of the CPS before it`s connected up.
Neil.
We know black/grey pin No 1 is ground so why can't you put a meter set on Ohms across pin No1 & No2 then No3 to see which is the signal & which is the positive ?
The only problem is G28 needs to see rotation to switch. 🤔
Posted 18 August 2019 - 05:32 PM
I`ve done that. I get 1K across 1 and 2 . I get 5m across 1 and 3. But that doesn`t tell me which is
signal and B+
G28 will "fire" with just a metal object moved across it
Edited by 0120raptor, 18 August 2019 - 05:33 PM.
Posted 18 August 2019 - 06:30 PM
DellI`ve done that. I get 1K across 1 and 2 . I get 5m across 1 and 3. But that doesn`t tell me which issignal and B+G28 will "fire" with just a metal object moved across it
Neil.
When you place a metal object across which set up do you see a change in the resistance state as the one where there is a change will be the signal & ground then the other will be the positive.
No1 is already knowen to be ground if you get my train of thought mate.
Posted 18 August 2019 - 06:36 PM
You`re a clever guy. Sorted. 1= B+, 2 signal , 3 ground. Thank you.
Posted 18 August 2019 - 07:51 PM
It’d result in a reply of “has it got carbon on it” or “your breaking forum rules by asking such a technical question”
Posted 18 August 2019 - 08:19 PM
Posted 18 August 2019 - 09:43 PM
You wouldn’t get this sort of advice on the other forum It’d result in a reply of “has it got carbon on it” or “your breaking forum rules by asking such a technical question”
That's why I'm on this forum & not over there mate.
Posted 18 August 2019 - 09:50 PM
Del
lYou`re a clever guy. Sorted. 1= B+, 2 signal , 3 ground. Thank you.
Neil.
Your most welcome mate đź‘Ť
Edited by RS3Dell, 18 August 2019 - 09:56 PM.
