I`ve had enough of the OEM magride dampers. I fitted Eibach springs a while back and these were a vast improvement over standard springs. Recently I`ve been getting a clunking noise front and back both nearside. Got it on the four post today. Rear nearside damper doesn`t damp anymore. I also need a host of rubber bushes front and rear. Whilst I`m at it I may as well change all four dampers and fit the delete kit. My question is which dampers will give a better ride than OEM. I`m not after the ultimate track car just something more comfortable than standard.Really I`d like to keep the Eibachs. Also which delete kit is best and is it really needed.If I`m just left with a dash light I can live with that.
Getting rid of magride
Posted 16 May 2019 - 06:13 PM
Posted 16 May 2019 - 07:44 PM
Neil.
Bilstein B8s dampers if they will fit The backs won't be a problem but the oem short length fronts may cause you one.
Posted 21 May 2019 - 04:54 PM
I`ve just found out Bilstein don`t do B8 dampers for RS3. Only 12,14,and 16. These already come with Eibach springs fitted . That`s no use as I already have these. Does nobody else make dampers for these cars ?
Posted 21 May 2019 - 06:25 PM
Neil.
The B12s are i believe B8s with non adjustable Eilbach springs fitted.
Be creative & look at the RS as just another A3 but with lowered springs fitted mate.
Posted 21 May 2019 - 06:38 PM
I got it wrong. Bilstein don`t do B12`s either for RS3. I don`t want to go coilover. Surely dampers for a humble A3 would be super soft.
Posted 21 May 2019 - 06:53 PM
Neil
From what i found on the 8P the B8s & the B14s dampers had twice as much compression damping as the stock front dampers.
My B14s are just run of the mill fiterment for a petrol/diesel 8P Quattro.
The problem is getting a dampen short enough to accommodated your Eilbech springs mate.
Posted 21 May 2019 - 07:20 PM
Neil
My Eibachs do lower the car but not because they are shorter . They are softer than standard hence the lowering but are in fact the same length as standard so shorter dampers are not needed.
Posted 21 May 2019 - 07:50 PM
Neil.
The 8v RS oem dampers may be shorter than say a S-Line or SE A3 one's.
If there not then you could use any quality aftermarket dampers to complement your Eilbachs mate.
Posted 21 May 2019 - 07:53 PM
Neil.
Good point .I hadn`t thought of that. I`ll give google a bashing.
Posted 21 May 2019 - 07:58 PM
Posted 21 May 2019 - 08:04 PM
Neil.
I tryed using B8s with just the Eilbach front spings but found they where 25mm to long so i had Bilsten UK shorten them the required amount.
The problem i then had was Eilbach don't do matching rear springs for the 8P so i sold it all off & fitted B12.
The RS3/S3 8P is 10mm lower again than an S-Line.
