Front Discs 380mm
Posted 02 May 2019 - 12:03 PM
Quick question please guys, Im gonna change my front discs in few months and i am looking at the 380mm ones not sure what brand yet. Will these fit with the standard calipers and fit on standard 19" alloys without any problems, Cheers all,
Ryan
Posted 02 May 2019 - 12:30 PM
Hi all,
Ryan
Need to speak to whoever you go with tbh mate.
Posted 02 May 2019 - 12:36 PM
From looking at the Reyland website you will need a caliper mount and some longer caliper bolts for their big brake kit. The reyland 370 discs I have fitted are performing much better than the standard discs I am very impressed with them.
Martin and Tony seem very knowledgeable about what is required and the kit I got from them was a simple bolt on.
http://www.reyland.co.uk/audi-front/
Edited by mattwez378, 02 May 2019 - 12:36 PM.
Posted 02 May 2019 - 12:46 PM
Posted 02 May 2019 - 12:47 PM
Cheers Buddy and Reyland aren't to far from so i will definitely give them a bell.
Posted 02 May 2019 - 12:48 PM
Posted 02 May 2019 - 03:26 PM
Hi all,
Ryan
For a car being used for fast road use you will find the Reyland 370mm two piece grooved discs are a good upgrade over stock items. I would recommend the DS2500 pads (Reyland recommend these too) as these have really good cold temp bite and great fade resistance. They do not have wear sensors but just use the OEM sensor connector from the old stock pad (there is only one) cut the wire and twist the ends together. Add some heat shrink to protect the join and then plug it back into the car to avoid a brake light warning on the dash. Its easy to see how much pad material is left by simply looking through the caliper when you wash the wheels.
Edited by Fivepotfan, 02 May 2019 - 03:27 PM.
Posted 02 May 2019 - 05:07 PM
Posted 02 May 2019 - 05:18 PM
Posted 02 May 2019 - 05:20 PM
Posted 02 May 2019 - 05:21 PM
Posted 02 May 2019 - 07:29 PM
How much are the ds2500 pads front and back???
Hall.
Do.you have a 8P or 8v mate ?
Posted 02 May 2019 - 07:48 PM
Posted 02 May 2019 - 08:21 PM
Posted 02 May 2019 - 08:28 PM
Posted 02 May 2019 - 08:30 PM
Posted 02 May 2019 - 08:34 PM
Posted 02 May 2019 - 08:39 PM
Edited by Hall1979, 02 May 2019 - 09:26 PM.
Posted 02 May 2019 - 09:16 PM
edit that picture mate (top section). Never know who views these pages.This the part number for the fronts??
Edited by JayRS3, 02 May 2019 - 09:16 PM.
Posted 02 May 2019 - 09:19 PM
Sign In
Create Account
Back to top
