8P0 051 961 Not 8P0 051 961A two different kits!
“kompatibel mit Radio Concert, Symphony und Navigation”
Features
Amplifier
The kit contains a vehicle specific mounting bracket and cable harness.
This high performance digital amplifier delivers clean, powerful sound and features a built-in DSP (Digital Signal Processor).
Specifically designed for Audi A3, S3, RS3
The amplifier features settings developed to accommodate left hand drive vehicles as well as right hand drive vehicles.
Speakers
2 Way component front system
2 x 16.7 cm midrange speakers (front door)
2 x 25 mm silk dome tweeters (front door)
1 x 16.7 cm mid-woofer chasis
Using Factory harness and connectors to allow plug and play for door speakers
No sound tuning needed.
Just look up car and driver parameters in the manual and select the appropriate setting.
Accurate stage impression for drivers of any body size.
Increased sound pressure level without distortions.
Deadening kit
Installation manual
Specifications
Compatible Cars
Maker Model Model year Factory Radio
Audi A3, S3, RS3
3 Door , Cabriolet (8P),
Sportback , 5 Door (8PA) 2003 - 2013 Concert,
Symphony,
RNS-E
Note: this product is not compatible with Chorus Factory Radio.
Ummm, are you planning on fitting this to your RS3?
Not compatible with RNS-E which is usually fitted to our cars: https://shops.audi.c...s-8p0051961a-10
What do you have in your car?
Edited by Renga, 29 March 2019 - 11:47 PM.
