A few changes.......
Posted 05 January 2019 - 09:54 PM
Reyland 2 piece discs with curved slots
Coupled with these Delphi Lockheed Pads front and rears
Now I ran into a fitment issue with the Delphi front pads.
The peg slot cutout isn’t big enough which I believe is down to a manufacturing issue.
As it was a weekend I had to modify the slot with my trusty Dremel to open it out a little, as you can see below the Delphi pad with an OEM one on top for reference.
Picture below shows how they wouldn’t seat properly.
And after a little fettling
I’ve been speaking with the Delphi technical rep and they have asked for various pictures etc and are looking into why this has happened, they have been pretty good about it.
The upshot is now I’m 100% happy with the way the car now brakes, zero squeal after a good 3 weeks of use.
The Reyland disc / Delphi pad combo is working miles better than I could ever have imagined.
One thing I did notice when changing the rears to Delphi pads, the drivers side pads were stopping the caliper from sliding back and forth, so much so that I was getting brake noise when turning at low speed (pads kissing rear disc)
Now part of this is down to me fitting the Ferodo DS rears ‘dry’ and not lubing T/L shaped lugs, my own fault as I pretty much dry fitted them as per oem and they were a loose fit in the caliper, so I thought they’d be fine, turns out in the space of a few months the lugs on 1 side had started to seize in the carrier.
Made sure the Delphi rear pads were well lubed up this time.
Used this.
On another brake related note
Upon swapping the Winters onto our GTD Golf I noticed that the rear pads on both outside faces had parted company with the friction material.
I can only put this down to long periods of it being parked up in bad weather and the moisture bonding the pads to the discs
It only affected the outer pads, inners were fine.
Brembo pads too that were fitted with new discs in April 17 so not that old really.
Next mod is the 034 rear anti Roll bar.
https://uploads.tapa...fa52e38cc44.jpg
https://uploads.tapa...43a305e2c21.jpg
https://uploads.tapa...dccb8d65674.jpg
I was concerned the oem end links would prove troublesome to undo, however a soaking of Würth Rost Off soon sorted them.
I greased them up on re-assembly
https://uploads.tapa...d053bf6e332.jpg
Since fitting this the car feels flatter in the corners and the whole rear end seems ‘tighter’ to me.
I actually think it has a positive effect on the front too when cornering.
I like the 034 product, the clamps/brackets have built in Grease nipples and they are substantially thicker than the oem brackets.
https://uploads.tapa...60389ff3273.jpg
Posted 05 January 2019 - 10:19 PM
I have had 2 FL RS3s now in the past 13 months and the brakes have only squealed twice - the first time on RS3#1 pulling out of the delivery bay and the second time in RS3#2 with teenage daughter #1 on board who said 'that sounds really sh*t). Told her that all it needs is a few really hard stops so she said 'go for it'.
Having nearly put her through the windscreen twice the problem went away. She might have learned to shut the f*ck up in future as a useful by product.
I think the solution to the issue is to drive it like you stole it all of the time. Hard on petrol but kind on the ears.
Posted 05 January 2019 - 10:26 PM
Thing is ED is mine was great until just over 5K miles then it started and wouldn’t stop no matter how I braked or what pads I tried.I have had 2 FL RS3s now in the past 13 months and the brakes have only squealed twice - the first time on RS3#1 pulling out of the delivery bay and the second time in RS3#2 with teenage daughter #1 on board who said 'that sounds really sh*t). Told her that all it needs is a few really hard stops so she said 'go for it'.
In the end I blame the oem discs, it’s almost like once a layer of the metal has been worn away the disc metal structure has changed and the squeaking started.
Posted 05 January 2019 - 10:39 PM
Weird - in RS3#2 I had no noise until about 7k miles (having done a load of holiday gentleish driving with family on board) - a few hard stops and job done. (it didn't shut teenager #1 up btw - as gobby as ever I have to report).
Posted 06 January 2019 - 07:50 AM
Edited by MarkMac-RS3, 06 January 2019 - 07:51 AM.
Posted 06 January 2019 - 08:55 AM
Worth every penny in my opinion.I might have to invest in Reylands for my 8V. I took the Reyland/DS performance combo off my 8p yesterday and put the standard discs and pads back on ready for it moving on. I had forgotten how crap they really were!
I original was going to have BG development make me a set of using AP blanks but couldn’t justify the cost.
I’m going to change the rear discs later this month for Reyland 350 Dia items.
Posted 06 January 2019 - 03:15 PM
Delphi have sorted those front pad peg slot.Perfect fit. I am happy with the Ferodos at the moment but they have started to wear
the discs.Probably too much metal in them.So decided to give the Delphis a go.
Posted 06 January 2019 - 04:01 PM
Yes Neil they are checking them.Sean
I’m getting a new set in due course from them.
Posted 06 January 2019 - 06:16 PM
Sean
I have just binned my DS Performance pads for DS2500's because they did not perform the same as the previous set I had with the Alcon discs on my PFL car. The DS2500's and the Reyland disc combo are now working really well and I am especially pleased with the low speed/cold bite they provide.
Edited by Fivepotfan, 06 January 2019 - 07:42 PM.
Posted 13 January 2019 - 04:18 PM
How are your Delphi pads coping ? I put them on mine .They are terrible. Refitting Ferodos tomorrow.
Posted 13 January 2019 - 04:31 PM
Fine Neil no problems up to now.Sean
When you say they are terrible, what’s wrong with them ?
Edited by T-800, 13 January 2019 - 04:31 PM.
Posted 13 January 2019 - 04:50 PM
After bedding there just wasn`t the stopping power as before.Today I had a bit of a play on my favourite road.They
seemed to stop ok but needed more pedal pressure. Stopped off at a pals for a cuppa.Setting off the car would`nt
move.Eventually with loads of revs and a crack it moved. The rear pads had stuck to the discs.Going home they went
bang,bang,bang as the pads hit the stuck spot. This went away after a bit but there was an almighty humming noise
that also eventually disappeared. When I got home the front discs were blue.This humming and blueness is just the
same as I used to get with the Redstuff.
Posted 13 January 2019 - 05:04 PM
Sean
How weird.
Never had them sticking on yet and mines outside all day long.
The bedding in procedure is no heavy braking on these for 100 miles.
The only pad sticking I’ve experienced is on the Golf GTD rears where the pads split in half.
Posted 13 January 2019 - 05:55 PM
Posted 13 January 2019 - 06:11 PM
Admit not to doing 100 miles first.Probably only 50 . I`ll give them a few more miles then see. How`s the VC ?How weird.
Posted 13 January 2019 - 06:20 PM
I’ll be honest, was sceptical about light use before any serious braking, however I did follow it to the letter, that point was re-enforced by Martin at Reyland, even if I switched pads to more aggressive ones at any point, he said the bedding in it was always important to follow the pad manufacture method.Admit not to doing 100 miles first.Probably only 50 . I`ll give them a few more miles then see. How`s the VC ?
VC has been ok since the hissy fit.
Edited by T-800, 13 January 2019 - 06:28 PM.
