MOT time
Posted 25 November 2018 - 06:16 PM
Posted 25 November 2018 - 07:07 PM
Emissions pass easily, barely a 0.1% difference fitted or not.
Technically it should fail where cats missing where usually fitted, but unless your Audi and know it has 3, or a car to compare against all is good.
Same if you fitted a sport cat. Technically it’s less cats than it left factory with and shouldn’t pass.
Edited by Paul, 25 November 2018 - 07:10 PM.
Posted 25 November 2018 - 08:06 PM
Posted 25 November 2018 - 09:18 PM
Don't Milltek state "race use only" or something on each pipe?
Tommy.
As TX said Miltek have "race use only" tags on both pipes just get the tags removed & your be fine at a normal mot station & not at Audi as Paul pointed out mate.
Edited by RS3Dell, 25 November 2018 - 09:19 PM.
Posted 25 November 2018 - 09:58 PM
Swift blow with sharp chisel will sort.
Posted 25 November 2018 - 10:39 PM
Forgot about the Milltek tags, I bought Scorpion.
Paul.
I had the Scorpions 1st but then decated the oem one's so the underside looked fully standard mate.
Posted 25 November 2018 - 10:46 PM
No worries chaps nice one, will have to see what the lad doing the MOT says if it fails will just swap them back then take it back in then swap them back again only 4 nuts on each pipe really so not much effort involved
Tommy.
I removed the decated 2nd oem one's & refitted the stock oem 2nd cats which take an hour last year due to the decated down pipe & it pasted easily
Posted 26 November 2018 - 01:45 PM
Posted 26 November 2018 - 01:58 PM
Dell , I did the same, bought a spare set of cats and gutted them, (very messy) then had through the “can” sleeved and welded in from the flange through to keep the bore consistent throughout, made a lovely job, oem look, but it droned like a biatch, so was taken off within 50miles and sold. They went on a TTRS in Scotland, but funded the scorpions instead.
Paul.
How strange i did just like you bought a spare set & gutted them,but didn't sleave them as there's no real need tbh That may have been the cause of your drone as i don't suffer from it at any rpm,engine load or road speed with the stock back box in normal or sports mate.
Posted 26 November 2018 - 03:39 PM
Posted 26 November 2018 - 04:44 PM
Could well be, at the time I was advised not to have the increase in diameter at the can swelling, only for it to reduce again shortly after, so had it sleeved it for a straighter flow.
Paul.
Adding a sleave is no different to a cat delete in reality mate.
Posted 27 November 2018 - 06:26 PM
