How many 02 sensors on the rs 8p
Posted 11 November 2018 - 07:40 PM
Adjustable 304 Stainless steel Lambda O2 Oxygen Sensor Exhaust Boss M18x1.5
SKU: LB1899S
Posted 11 November 2018 - 07:46 PM
Looking to change downpipe &mid pipe to delete cats anyone know if you can just fit 1 or is 2 needed of these to stop engine check light coming on
SKU: LB1899S
The one after the primary cat is the one which does the check & needs to be switched off mate.
Don't touch the 1st one on the turbo as that does the fueling mate.
Edited by RS3Dell, 11 November 2018 - 07:48 PM.
Posted 11 November 2018 - 07:56 PM
Changed downpipe & 2nd cat fitted the dog legged sensor adapter now have engine check light illumination on dash after 2nd outing in car bit worried if to drive or not now , any help would be greatly appreciated
Posted 11 November 2018 - 08:01 PM
Posted 11 November 2018 - 08:09 PM
Have stage 1 revo so far do I now need to go to stage 2 to eliminate as thought the dogleg sensor would eliminate engine check light ??
To be safe & too get the most out of your mods a remap will need be done to support them mate.
Posted 11 November 2018 - 08:23 PM
Thought so just thought I’d give it a try with sensor ,
any suggestions on the mapping been happy with the revo stage 1 just looking if any other tuner you may recommend with your vast experience
Posted 11 November 2018 - 09:01 PM
Thanks Dell Thought so just thought I’d give it a try with sensor , any suggestions on the mapping been happy with the revo stage 1 just looking if any other tuner you may recommend with your vast experience Sent from my iPhone using Tapatalk
Don't Revo do a stage 2 map to facilitate your up coming mods.?
Mine's been customed remapped at MRC in Banbury running the mods at the bottom off my page mate.
Posted 24 November 2018 - 04:06 AM
Engine check light reset itself , must be how it reads as no sign of now mods getting done with mrc hope to get as many n/meters as you 7 hundred + wow
Posted 24 November 2018 - 07:13 AM
Just thought I’d mention dell
Happy Days mate 👍
