Starting issues
Posted 14 October 2018 - 07:51 PM
I’ve had my 8P for a few months now and apart from a replacement haldex pump everything is tickety boo.
But I do have an intermittent issue, sometimes when I start the car it seems to turnover for quite a while before it fires, then other times it’s fine?
I’ve heard som people mention spark plugs are a weak point, just wondering if anyone has had a similar issue?
Posted 14 October 2018 - 07:57 PM
Evening all,
Spark plugs are to be changed on a standard engine at 19k using oem one's.
Do you get any dash warning lights ?
Posted 14 October 2018 - 07:58 PM
You’ll then have more idea what’s what.
Hi dell, cheers for the reply.
Nah no dash lights and nothing in vagcom either, doesn’t seem to be missing or lacking in power just seems to hesitate to start on occasion
Posted 14 October 2018 - 07:59 PM
Best starting point get a scan if possible by someone local with VCDS.
Op's glad you picked me up on that one mate.
Posted 14 October 2018 - 08:02 PM
Ok do you know when the plugs were changed last ?
Edited by RS3Dell, 14 October 2018 - 08:03 PM.
Posted 14 October 2018 - 08:03 PM
Ok do you know when there plugs were last changed then ?
I must admit I didn’t know the interval of 19k, I’ll check it when I’m back home tomorrow hopefully that’s it!
Posted 14 October 2018 - 08:08 PM
I didn't know either when i 1st serviced my RS as my previous A3 was 60k
Posted 14 October 2018 - 08:12 PM
Haha we live and we learn! Hopefully that’s all it is. Did you just use OEM plugs or go for an upgrade?
Posted 14 October 2018 - 08:19 PM
Non mapped engines use oem even my remapped RS i use them but i change them at 10k.
Posted 14 October 2018 - 08:21 PM
Coll, cheers man good to know!
Posted 14 October 2018 - 09:33 PM
Posted 14 October 2018 - 09:47 PM
on vcds. Thoughts anyone?
Posted 15 October 2018 - 05:31 AM
I would hazard a quess on it`s not building up fuel pressure quickly enough. Once it`s started nothing would show
Neil.
I'll check to make sure the ECU has had all its software updates before changing parts to trace this problem.
To check what software is installed going into engine & check the last 4 numbers at the top off the screen.
The last four numbers should be 0060 not 0040 or 0050 if its up to date.
I'll also change the plugs 1st if you don't know there history.
Edited by RS3Dell, 15 October 2018 - 05:42 AM.
Posted 15 October 2018 - 07:09 AM
I’m assuming this problem doesn’t only occur during a cold start?
Have you tried leaving the ignition on a couple of seconds to prime the fuel system before cranking the engine over?
Posted 15 October 2018 - 07:46 AM
I put new plugs in for the first time in my ownership and it made no difference for starting so presumed it was me just trying to ‘jump the gun’
Posted 15 October 2018 - 08:34 AM
So I suppose you could ‘catch’ it out if you were really quick on the draw.
I asked the dealer about it but was met with the usual blank face and shoulders shrug.
Posted 15 October 2018 - 08:46 AM
Yes that’s correct, @Quattro mine had an ecu update in 2013 and after the update it never primed the pump upon the driver door being opened, only on the key.
On my old A3 3.2 the pump would prime on opening the drives door.☹
I did notice when i first got my RS that priming the pump had been done away with.🤔
All the old PD diesels would do the same for the glow plugs rather than you having to wait for the warming up light to go out.😊
Posted 15 October 2018 - 08:49 AM
Yes Dell as did my 3.2TT
PFL primed as does the FL.
My thoughts are that the fuel pressure drops away over night and the system takes a tiny amount of time on first start.
Be easy to see why it would turn over a little longer after being stood.
An easy test is to turn key let the pump prime then start.
Posted 15 October 2018 - 10:44 AM
fuel pressure in the line should not back bleed a one way valve is put in place to prevent this.
Also i wouldn't always rely on software to fix an issue, if anything Audi try masking an issue with software.
If the fault has only started after an update then yes go back and talk to your local Audi. If the fault has randomly started then go back to basics and work out what could cause this problem.
Reason i suggested battery is vehicle sensors can not read if voltage drops below 10.5V and cranking a vehicle over on a 3 year old plus battery could cause this. I have seen it several times over the years.
