Gearbox mount replacement DIY?
Posted 19 September 2018 - 03:51 PM
Got a bit of creaking at low speed coming from front passenger footwell, mainly on cold days, and only noticeable at low speed (assume cabin noise takes over at higher speed).
So I am assuming the gearbox mount is on it way out.
There is a video from ECS and Black Forest on replacing the mount on a 8p s3 and I have read the replacement guide on Elsawin for the RS3. Seems similar minus the supporting of gearbox...
Elsawin shows some fancy top mounted winch pulley thing. The videos and guides for the s3 just show supporting the gearbox with a trolley jack.
Is it ok to do this on ours? I assume you just jack it up and remove the plastics covers under the engine. Then once removed where do you place the trolley to support the box?
Has anyone ever done a diy gearbox mount replacement?
Mounts are expensive but I assume if it’s starting creaking it best to replace to prevent damage to gearbox or prop shaft?
Sorry for all the newbie questions! All words of wisdom are greatly appreciated!
Ollie
Posted 19 September 2018 - 03:59 PM
Remove airbox to expose gearbox mount.
Order new gearbox mount along with new bolts (important) approx £300-£350.
Using trolley jack support the gearbox from underneath to take the weight/stress of the mount.
Undo 3x bolts on mount.
Replace component.
Install new bolts, torque them up.
Release weight from jack.
Refit air box
Test drive
Edited by JayRS3, 19 September 2018 - 04:00 PM.
Posted 19 September 2018 - 04:42 PM
Posted 19 September 2018 - 05:14 PM
What Jay just said, with maybe a cup of tea to break up the job
Have some friends round at the same time to go with the Tea & biscuits.
Posted 19 September 2018 - 05:37 PM
Thanks Jay!!!! Yes the new bolts!!!! They stretch right? So one time use.
It’s purely the supporting the gearbox that was making me nervous. Am I right in assuming the plastic cover underneath needs to come off?
Any advice on jack placement?
Ollie
Posted 19 September 2018 - 05:49 PM
correct, undertray off.Afternoon tea?? How very English. I assume custard creams are a toolbox essential?
Ollie
When it’s off you’ll see the gearbox clearer, just find a relatively flat-ish area that’s central and you’ll be fine. Only needs the weight taking off it slightly.
Posted 19 September 2018 - 05:50 PM
Ollie.
Under tray off & then lift the gearbox to take the weight without it going pissed or your have problems aligning the bolts when refitting the mount.
Posted 19 September 2018 - 05:53 PM
Ollie
Ollie.
Yes custard creams or rich tea.
Posted 19 September 2018 - 05:55 PM
Thanks guys! Really appreciate the guidance! See you at RS3 fest
Ollie
Ollie.
Bring a jack & tools we do it there
Posted 19 September 2018 - 08:29 PM
Posted 19 September 2018 - 09:12 PM
Dell that’s a very kind offer but you should be enjoying the day and getting ready to test your new brake set up on the track not fixing my car!!
Ollie.
If you lived near south london/kent ill would be more than happy to help you do it or do it for you mate.
Posted 20 September 2018 - 07:28 AM
Ollie.
Bristol based unfortunately Dell. But I would probably make the journey in the future.
But this time I reckon from the info I already had and guidance above (thanks Jay & Dell) I should be able to replace it myself. I absolutely love the car so I am really keen to work on it myself as much as possible (tools and ability allowing!)
Shame 034 haven’t sorted out a street density oem replacement.
Ollie
Posted 20 September 2018 - 07:48 AM
Ollie
Ollie.
Posted 04 October 2018 - 06:22 PM
Can anymore confirm if this is a genuine RS gearbox mount? Been provided the dealer who sold the car to me. He described its condition as “like new, only used briefly, can hardly tell it’s been used”.
Based on the oxidation on the casting I am not convinced. Rubber seems ok, and the back plate. Which further makes me wonder whether it’s refurbed, possibly original casting by new internal runners and back plate.
Also creaks and squeaks like an old bed and has a lot of front to back movement, is that normal? How stiff should the mount be? YouTube video to follow once I work out how to upload.
Thanks in advance guys!!!
Ollie
Posted 04 October 2018 - 06:37 PM
Posted 04 October 2018 - 06:48 PM
That's the right one up to 05/03/2012 after that date it will be part No 8P0 199 555 A & there not refurbishable.
Hope this is of help mate.
Dell
Edited by RS3Dell, 04 October 2018 - 06:56 PM.
Posted 04 October 2018 - 07:19 PM
Ollie.
Dell
Hi Dell,
Cheers! Yes ETKA seems to suggest that to!!! Like new part my arse.
I assume it shouldn’t creek like that???
Ollie
Posted 04 October 2018 - 07:25 PM
Hi Dell,
Ollie
Ollie.
I just looked it up on 7zap on my phone mate.
